Cam Specs (neon)
So i wanted to get some opinions from some of the people here on the differences between the cams available to my car. SOHC is obviously going to be the best for mileage, as the cam grind is not only better, but the valves are smaller. But how about the difference between the DOHC cams. The first is off a neon, the second is from the stratus.
Neon DOHC Cam
Intake Duration: 219.2
Exhaust Duration: 219
Intake Lift: .344
Exhaust Lift: .314
98 Stratus Cam
Intake Duration: 232
Exhaust Duration: 240
Intake Lift: .324
Exhaust Lift: .256
as you can see the stratus cams have more duration, but less lift.
just for fun
SOHC Cam
Intake Duration: 207.2
Exhaust Duration: 229.1
Intake Lift: .283
Exhaust Lift: .277
