Old 05-13-2009, 10:25 PM   #21 (permalink)
Lurker is indeed accurate
Just off, the 1951 Chevy Pickup would have a curb weight of 3200lbs or so. I found several different numbers. Looks like some of the hot rodders have put aluminum beds on them for weight savings.
Also most of the older stuff will be rear wheel drive. That has to make things less complicated right? Maybe lets me put a little bit of battery weight on the front axle. An in-bed truck box for weather proof battery storage. It's an interesting idea.
More research clearly needed,
-R
Old 05-13-2009, 11:18 PM   #22 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Originally Posted by Russ View Post
The 6 was indeed straight. Please excuse my oversight.
I'll sacrifice a Corvair to the pony car gods to make up for my blunder.
-R (noob)
HEY!!! You leave Corvairs out of it!
They aren't V6s anyway!
Old 05-14-2009, 09:20 AM   #23 (permalink)
Goodness, this is my 4th post and I've already offended two people. That's a pretty bad average. Maybe I should go back to lurking!
Old 05-17-2009, 11:05 PM   #24 (permalink)
That does bring to mind another question. Towing with an EV.
Now clearly electric motors can handle much higher weights/loads and voltages than they were designed for. A number of people have proven that. It's also obvious that towing is going to drastically affect range. Other parts of the equation match with gas-towing. Brake and tire wear in particular. Transmission if you have one.
I know electric "city trucks" have been around a while and can remember hearing about electric fleet vehicles in the 70s.
Plenty of torque available. What affect would towing have on an electric motor? Or an EV in total aside from the obvious range/brakes/tires/transmission bit?
-Russ
Article: Want cars to eat less? Put 'em on a diet MetroMPG General Efficiency Discussion 33 10-12-2008 07:54 AM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 09:26 PM
