Old 10-25-2009, 12:06 AM   #1 (permalink)
Question Can I get the application for MPGuino?
Hello!
I am trying to assemble the mpg meter for my corolla 2006. I am ok with microcontrollers and I have a programmer.
Could someone tell me if I can get the appliation or at least tell me where to read about how it functions? I need the info of what you are reading from the car and the formular of how to calculate the the MPG from those readings.
Thank you!
Old 10-25-2009, 12:14 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
application here:
opengauge - Revision 165: /trunk/mpguino
basically, it tracks the amount of time the injectors are open and determines the fuel delivered from there
it also tracks the distance if your car has an appropriate speed sensor hookup.
thus it can track and display distance, fuel used, distance/fuel (mpg), speed, gph, and a few other permutations.
The Following User Says Thank You to dcb For This Useful Post:
viva_unix (10-25-2009)
Old 10-25-2009, 12:21 AM   #3 (permalink)
Thank you!
do you know where I can find the wires location for corolla 2006?
Old 10-25-2009, 12:25 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
Me? no. Check the wiki, MPGuino - EcoModder
do take some pics and make a corolla wiki page if you sort it out.
Old 10-25-2009, 03:14 AM   #5 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 39.53 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 23.7 mpg (US)
Originally Posted by viva_unix View Post
Thank you!
ECM Pin 1 yellow wire is the number 1 injector wire.
ECM Pin 17 violet/white is the SPD wire.
Could not find one labeled VSS, hopefully the SPD is ok.
moorecomp
Mancelona, MI
Another Vortex Generator Application? jerm1978 Aerodynamics 14 02-19-2009 08:52 PM
Facebook MPG tracker application NoCO2 Off-Topic Tech 8 06-07-2008 01:14 PM
