Old 01-28-2009, 09:56 PM   #21 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I've been told not to idle the engine for extended periods as the chronic low oil pressure/flow can cause damage and premature wear. I don't remember reading anything on it though, and I've never had a need to actually test it.
Old 01-28-2009, 11:53 PM   #22 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
The main point -- not only is idling a potentially damaging proposition (especially extended idling during colder temperatures at startup), but is innately inefficient. 0 MPG.
Luckily, there is plenty of research by well-respected fuel economy experts, on the topic of idling. Even if it's -30F without an EBH, I start up, throw it in gear, wait for the fluid to kick the auto into gear, and slowly drive away (then pop it into 2nd to get the most out of the fast idle).
The previous paragraph contains an important EcoMod reference: the engine block heater. If I only had access to a 120VAC plug anywhere I park. 365/24/7 -- but on a timer. In the winter, maybe 3 hours -- summertime is about an hour.
Nevertheless, the added warmth allows a variety of efficient post-start benefits: including improved oil viscosity and flow. End of story.
Bear in mind that the grid is more efficient than your engine.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 01-29-2009, 12:03 AM   #23 (permalink)
Steve - '92 Festiva
When I start the car, cold or not, I let the engine RPM stabilize before taking off... this usually takes 5-10 seconds after it starts. This is usually enough time to grab the seat belt, put it on, and put the car in gear.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 04:17 PM
New York mechanic Andyman Introductions 6 05-13-2008 12:02 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
