Old 09-09-2011, 07:30 PM   #11 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
^^ I would but they already make pumps like that and they are held by a patent so i can't copy it :/
Plus I want to modify my existing pumps so I can just cut off their AC cord and 'splice' this "wireless inductance" gizmo in between it.
The AC cord would carry the 120v that gets stepped down at the pump, so I would need to do this kind of thing;
AC wire -> 120vac to 12vac -> "wireless inductance" | GLASS | "wireless inductance receiver" -> 12vac to 120vac -> pump
Old 09-09-2011, 07:30 PM   #12 (permalink)
But now I am stuck at the "wireless inductance" phase lol. need to pass 12vac to 12vac on the other side of the glass.
Old 09-09-2011, 10:20 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
seriously though, why cant the leads go in through the top like a normal fish pump?
Old 09-10-2011, 06:10 PM   #14 (permalink)
Aesthetics.
Old 09-11-2011, 08:45 PM   #15 (permalink)
sid
grayranger - '010 Ranger XL 2 door supercab
90 day: 31.09 mpg (US)
You can copy and build any patented item for your own personal use or for research without penalty. It is when you sell them, use them in a commercial setting, or even give a number of them to others that gets you in trouble.
One of the requirements of a valid patent is that others with reasonable skill are able to duplicate it from the patent description.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
The Following User Says Thank You to sid For This Useful Post:
Ryland (09-11-2011)
Old 09-11-2011, 09:01 PM   #16 (permalink)
dcb
needs more cowbell
dcb's Avatar
It is possible to drill through glass too, i.e. through the bottom, slow, with lubrication dam and special bit, google.
Note: I would replace the plug end of the pump after feeding the wire through the hole, to keep the in-tank pump power with the original sealing.
That's all I got for asthetics. Except that you could also put the tank on a vibrating table and wirelessly transmit some energy to it that way
Old 09-13-2011, 07:54 PM   #17 (permalink)
Custom User Title
Daily Driver - '02 Grand Prix SE
90 day: 18.45 mpg (US)
VorTech MP10 | EcoTech Marine
That's what you want, but without the incredible price. Aesthetics makes or breaks an aquarium IMO. I've seen these in person, and they are awesome, certainly worth the price. But the principle on which they work is simple, and doesn't require such a hefty $$$ premium. (I know those two statements conflict, but want and need have the same analogy)
Old 09-13-2011, 09:44 PM   #18 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...look-up their "patent" on how the system works and see if you think it's worth your effort to attempt DIY building one for your own use.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 09-13-2011, 11:19 PM   #19 (permalink)
dcb
needs more cowbell
dcb's Avatar
yah, if you can design your own pump. 3 phase coils on the outside, pm rotor on the inside of the glass, forget all that connectivity weirdness.
Old 09-14-2011, 12:32 AM   #20 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
There are a lot of magnetic pumps out there that have the impeller sealed off from the motor with out any direct mechanical connection, El Sid pumps are an induction pump that the only moving part is the impeller that is on the other side of a Stainless Steel plate, separated from all of the electronics.
Come to think of it, why not just a small diaphragm pump? much easier to build and on the out side of the tank you just have a coil that pulses on and off with a little iron or magnet button in the center of the diaphragm.
