Originally Posted by Superturnier
Would a smaller diameter piston be better, since there would be less area for the vacuum at the top of the piston?
So a "long stroke" engine would be more economic?
This is what I've always understood, but not as a matter of the vacuum above or below the piston.
See, if you increase the stroke, and decrease the bore, on a linear scale, (to keep things equal) you're still moving the same volume below the piston.
