Early shifting still works to an extent, since even in Vtec mode, the higher you rev, the more fuel units per minute you're using.
If your a/f ratio is a constant 13:1, and you're revving 2000 RPM with an engine that has 1.0 liters displacement, vs revving 1000 rpm with the same displacement (not counting volumetric efficiency, as this is just an example), you're using 2x the fuel per minute.
The difference comes with gearing. Are you using more or less fuel per distance?
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
