Old 06-02-2011, 10:35 PM   #1 (permalink)
Leviticus - '97 Sebring Convertible JX
90 day: 21.33 mpg (US)
Fiesta - '012 Fiesta SE
90 day: 30.53 mpg (US)
cap on car
My car is a convertible, so some mods are a bit harder, or altogether impossible, to do than on a normal car. But I had an idea, if I were to use a screen that goes from the top of the rear windows to the trunk to make a sort of cap, does anyone think it would be very effective? I remember reading in another post using screen as a grill block but someone said it would only work if the the screen was at an angle. I'm making a picture of my idea now.
In the morning sometimes there's leaves on my roof and as I start to drive they get stuck right on my rear window, the vortex there is clearly visible and must create quite a bit of drag, and it would be awesome to reduce it!
Old 06-02-2011, 10:40 PM   #2 (permalink)
Something like this, not very good with Internet drawing tools haha
there would be supports and stuff of course
Old 06-03-2011, 03:56 PM   #3 (permalink)
screen
My library is certainly incomplete and if there had ever been a dedicated research project to investigate such a thing,it could have easily slipped my net.So,scientifically,I can't give a hard answer.
Here are some things that enter my mind:
* air cannot support loads,so a porous surface as the screen may be 'invisible' to the air and will still be affected by any variations in flow velocity or pressure variations 'contained within the screened area.
* if separation is imminent,the presence of the screen may offer no 'surface' for which the flow to re-attach.
* if the surface had more substance( like the laser-drilled panels on some recent experimental research aircraft),and if suction were applied inside it,you'd have a chance for remarkable drag reduction.The snag so far has been the amount of power to drive the air mover.
* for practical home streamlining projects we may be forced to use 'solid' surfaces with which to enhance airflow.
* A doped fabric covering was used on the US' first amateur streamlined dry lakes land speed record car to good effect.
Old 06-03-2011, 05:07 PM   #4 (permalink)
Mercedes made a front windshield "wing"/deflector to relocate the flow above the drivers and thus the turbulant section.
Still aero but with the top open!
It's called aircap.
It has a cd of 0.28 !!
Mercedes-Benz AirCap calms convertible winds - Automobile Magazine Blog
Old 06-03-2011, 05:20 PM   #5 (permalink)
0.28 my foot.
OP, not sure what you are describing.
Old 06-03-2011, 05:36 PM   #6 (permalink)
roof up?
It's called aircap.
beer,do you think the Cd as recorded with the top up on the M-B?
Old 06-03-2011, 06:51 PM   #7 (permalink)
Top on! Duh
But still this the aerocap reduces the wake, compared with other cabrios.
But ofcours it main use is the keep the passengers out of the wind
Old 06-03-2011, 07:01 PM   #8 (permalink)
passengers
Top on! Duh
I think that's it.I drove the Autobahn in 1997.Doing 124 mph in a rented Mitsubishi Galant was passed by big 6-series Bimmers and Benz coupes and sedans.
Can't imagine what an open car would be like at those speeds.I don't even like 80 mph on a motorcycle.
Old 06-03-2011, 08:08 PM   #9 (permalink)
I don't think it's worth it. What you're describing is basically just what the soft top is.
Old 06-03-2011, 09:43 PM   #10 (permalink)
Tenderfoot
ChazInMT's Avatar
MagMetalCivic - '04 Civic EX
90 day: 37.18 mpg (US)
Looks to me like you need to use Tiny Pic for your photo hosting needs.
You wanna do something like this eh?
