Old 10-26-2008, 12:46 AM   #11 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
PS: I ended up starting my car the other day and the battery is still alive,
Old 10-26-2008, 02:07 PM   #12 (permalink)
cmags's Avatar
Scoob - '05 Impreza Outback Sport SE
90 day: 25.28 mpg (US)
Originally Posted by eco_modder View Post
How hard would it be to get setup values saved to flash memory?
Setup values are saved to flash memory. Pulses per mile, uS per gallon, etc. But now that you mention it, would it be that hard to have the raw data saved to flash memory so the thing didn't need to be on constant power? If you're out of variable space, how many of the setup parameters really need to be changed - can't we go back to hardcoded for most of those (of course you'd leave the calibration parameters in flash for dialing in)?
Just a thought.
Old 10-26-2008, 02:22 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I don't know that it's a problem guys. Someone please put their ammeter to it already.
Saving to eprom (not flash) is a bit of an issue because there are a limited number of writes, and of course you cannot write the eprom once the power is disconnected (which is when you would want to do it).
And of course there is the lack of space to do much of anything else coding wise with, i.e. some fancy power saving scheme.
Someone needs to test it.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Guess: how many "labour hours" to make a conventional lead acid car battery? MetroMPG The Lounge 16 10-20-2008 03:57 AM
Alt Car Expo Los Angeles 2008 cfg83 Events & Meet-ups 2 10-14-2008 06:21 PM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
