Old 08-06-2010, 11:32 PM   #11 (permalink)
I think my battery might need replacing. I've been suffering from starting problems for several months, but put it down to the frequent, short journeys. I bought a charger and have used it several times to top the car battery up. But as the weather gets colder, the battery is getting worse. Where do you buy yours?
Old 08-07-2010, 12:09 AM   #12 (permalink)
Lil Sulf - '94 Corolla
90 day: 47.62 mpg (US)
I think I might be having problems soon too. I was doing some heavy P&G at night (2 nights ago), and I was so worried about my new partial boat tail falling off or something, that I forgot about my heavy P&G. After minute+ light, with m headlights and radio on, I tried to start my car and it did not start.
After the jumpstart (thanks jumper!), and the errand I was on, apparently I forgot to take the key out of the ignition, and left the fan on the lowest setting and my idiot lights on all night. Needless to say I felt very stupid to have to jump my car twice within 24 hours. I did scrape off a lot of white corrosion from on top of the battery, and so far it starts like it should, but I'm worried.
Remember my 1100+ CCA post (page one)?
I went to advance auto and it was only 450 CCA
And it must have been 90+ degrees outside . . .
I really want an optima yellow top but they are so expensive . . . any suggestions? I live in a very hot climate, so I don't need a good winter battery, but I do P&G a lot, sometimes at night.
And that's without a Scangauge o.O
Old 08-07-2010, 12:38 AM   #13 (permalink)
insane in the propane
Cloud Car - '96 Stratus ES
90 day: 39.15 mpg (US)
batteries! good topic. i subscripe to the recycle type of mindset, i am cheap too. so i always buy junkyard batteries. they are $20 each, and i will only buy a battery that is 6 months old or newer. i abuse my batteries pretty bad, but they still last about 3 years a piece. i think this is due to the increased size that i use. let me explain.
my car has the battery UNDER the driver side headlight, in front of the wheel, and its inside the front bumper. kind of an odd place, but it helps create more engine room.
due to the limited size area in there, i cannot upgrade to a larger battery, but i can add extras! i added 2 diesel truck batteries to the trunk of the car and i put them in those plastic boat battery boxes. i ran 2 gauge cable from the front of the car to the trunk for my 2 extra batteries. my alternator is about 90amps max, so it charges all 3 pretty good. i am guessing the extra batteries and cable add about 70 extra lbs. but running alternatorless more then makes up for the weight penalty, with increased mpg's. remember my car is about 3000lbs, so an extra 70lbs is nothing. i don't even notice it.
the reason i have extra batteries is because i remove the alternator and a/c belt in the cooler months. during the summer i just disable the alternator with a switch on the dash so i can keep using a/c. since it's summer right now, i have the alternator switched off but still i use the a/c. i also turn the alternator ON when coasting to a stop to help keep the batteries charged. (part of the reason i change the charging voltage to 15.5v is to help charge those batteries quick under the situation when i am coasting to a stop and charging the battery at the same time) as soon as the engine rpm's drop to idle and i stop, i turn the alternator switch back off.
because of my nearly constant a/c usage, stereo, 12" sub and amp, headlights, etc i find that having 1 battery is not enough for running alternatorless in my car that seems to take a million amps. deep cycle batteries are too expensive. so junkyard batteries it is then! on a cool day with a/c off, subwoofer disconnected, and only the stereo on i can drive for a few hours with no alternator. but this is torture on normal batteries that are not of the deep cycle kind. that is why I chose to use larger diesel truck batteries. they store more energy, and are more forgiving when deeply discharged, and at the junkyard all the batteries are $20 each no matter if it's a tiny honda battery, or a large diesel truck battery. so why not buy larger if they are the same price?
if you do not ever run with the alternator disabled, then there is no point in upgrading to a larger battery, from a fuel economy point of view anyways. you might as well run a small honda civic size battery and enjoy some meager weight reduction savings.
96 stratus "es" v6 auto-stick
supplementary propane injection
injector kill switch, alternator kill switch
Charging system voltage increased to 15.5V
secondary and tertiary 12v batteries in the trunk
on-board battery charger
lights converted to led's
potentiometer controlled tps for ign timing
welded straight pipe in place of cat-cons
removed egr
3 inch body drop
90psi fuel rail & -50% low volume injectors
run 15% diesel 85% gas
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 172 07-20-2010 01:06 AM
start a "Fire" fly EV project Trevs Introductions 16 04-30-2010 09:00 PM
VW 2013? We shall see! DIMS EcoModder Blog Discussion 11 09-27-2009 10:35 PM
