Old 02-27-2008, 12:07 AM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
well... if other emissions go down, give a little on those to keep NOx lower. That's what I've been thinking.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 02-27-2008, 12:56 AM   #12 (permalink)
Christopher Jordan's Avatar
Gopher (aka- go fer...) - '95 Aspire 2dr hatch
E - Pod - '05 Velomobile EV/HPV
City-EL Targa convertible - '93 Targa YL/BK
Everything old is new again...
The Pinto came to my attention .....
Funny! I am sounding like some old historian- "I remember when..." But I had several Pinto station wagons in '75 to '85 since the 2-door design was ideal for me. Pinto Squire was my favorite since it had AC; and yes- I had a long recumbent trike way back then and it fit right in!
Hot Rod or Car Craft made a project Pinto wagon starting by adding on a long nose, chopping the top 2" and lowering the whole thing- Project Droop Snoot. Much more power; they stuffed a 302 V-8 in, then all that problem with burning gas tanks ruined that car.
The Aspire is as different as you can get, but it gets double the mpg any of the Pintos got.
countersTrike
Old 02-27-2008, 03:47 AM   #13 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 43.46 mpg (US)
Hello -
Google google google ... Here's the issue :
http://usedmagazines.com/titles/Car&Driver/1974/
Look for Car and Driver March 1974
CarloSW2
American Solar Energy Society
Old 03-08-2008, 12:26 AM   #14 (permalink)
Cd
no
Cd's Avatar
( Car & Driver also did a follow up on this article using a Datsun 240Z. )
Old 03-08-2008, 12:27 AM   #15 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Welcome to the site .Cd! Any idea where we could find that article?
Old 03-08-2008, 02:12 AM   #16 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Originally Posted by RH77 View Post
I agree -- and have thought quite a bit about this.
We can make engines more efficient from a consumption standpoint, but emissions nevertheless increase. A catalytic converter and EGR setup are supposed to remove most of the NOx. Newer tech (although more expensive) could be implemented.
Too bad it's one or the other right now...
RH77
You can limit NOx by running lower combustion temps, but that generally means low compression and no lean burn. The lean burn can be overcome with EGR (inert gasses limit combustion intensity, and therefore temperature). This technology is applied to Honda's new 2nd gen. L-series engines, more efficient and cleaner than the D15z1. Traditional catalysts won't work in a lean burn environment because they require HC and the absence of O2 to transform NOx into N2 and O2.
The only legitimate technlogies that I know of right now are NOx adsorbers and Urea injection. I'm sure other stuff is in the works.
  • NOx adsorbers, as used on the Insight, are merely sponges that soak up NO during lean burn operation. The Insight either purges the adsorber by running rich momentarily or just through stoichiometric burn driving.
  • Urea is commonly used by truckers in Europe, but it requires the hassle of an extra fluid and is energy intensive to make. The production of ammonia (basic component of Urea), mainly for fertilizer, is one of the most energy intensive processes in the US as far as I know (Haber Process, I believe). Not good for the holistic hypermiler I guess...
For those who care about the environment, forsaking NOx for mileage may be a bad idea. NOx is photochemical smog (Los Angeles), and a stronger greenhouse gas than CO2. It is also toxic and triggers allergies in some people...really, driving a car is like urinating in your water supply. We humans so smart.
- LostCause
Old 03-08-2008, 04:37 AM   #17 (permalink)
good way to put it.
Old 03-08-2008, 03:50 PM   #18 (permalink)
Ninja Tornado
RH77's Avatar
Teggy - '98 Integra LS
90 day: 35.44 mpg (US)
- LostCause
So true.
I'd like to get an emissions test performed to see what's going on -- not required on this side of the State.
What would be interesting, is to examine the application of the new "Clean Diesel" catalysts to gasoline emission systems (urea-free, low-maintenance).
Also, the Honda K-series engines were designed without an EGR -- instead, variable cam timing keeps the valves in a position to utilize post-combustion product, at idle.
RH77
_______1998 Acura Integra 3-Door, Automatic _______
Old 03-08-2008, 07:39 PM   #19 (permalink)
Pokémoderator
cfg83's Avatar
.Cd -
Welcome to EM! My wife had a 260Z, so it would neat to read that article.
CarloSW2
Old 03-12-2008, 04:15 PM   #20 (permalink)
Blackfly - '98 Metro
90 day: 78.84 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 106.27 mpg (US)
Oh? I'd love to see that too.
FYI - I added pics of the Pinto to the first post in this thread, so you can go back up to see the massive air dam, grille block and rear spoiler they made.
Also made it an EM blog post, so if anyone here is a D I G G E R, check here: http://digg.com/environment/Car_and_...percent_for_11
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 12:51 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 10:37 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
