Old 11-14-2009, 12:56 AM   #1 (permalink)
Troy - '94 Galant GS
90 day: 36.63 mpg (US)
Greenie - '94 Metro LSi
90 day: 55.23 mpg (US)
Not-so-Grand Am - '98 Grand AM GT
90 day: 32.04 mpg (US)
Car shaking?
Been a long time since I posted here....a problem with my car is what has brought me back.
Recently my car started shaking when I accelerate. The problem started happening all at once, not gradual at all. It shakes vehemently in every gear, primarily during acceleration, but also to a lesser extent if I am simply pressing the gas pedal. In the limited driving I have done with the car, I've resorted to a lot of gas saving techniques like neutral coasting and EOC, because this is the only way to really reduce the shaking. The shaking does appear to be slightly lessened if I drive the car in a lower gear and thus a higher RPM. This problem has also significantly impacted the performance of the car. For instance, it has difficulty maintaining highway speeds in 5th gear, and acceleration is impaired. Additionally, the car is idling poorly. The tach jumps up and down between 600 - 1000 RPMs. Perhaps it is just anecdotal but it seems to idle WORSE after the car has warmed up.
Any help you guys can give would be greatly appreciated. I just got a new apartment and have a lot of expenses, so my hands are really tied in terms of professional help. I am hoping someone here can help me diagnose it, and I can get a manual and fix the problem myself.
And in case it helps, it is a 1994 Mits Galant.
Thanks!
Old 11-14-2009, 10:08 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
The jumpy idle sounds like a vacuum leak. Less likely would be a sticky IAC valve.
As for the shaking, is the check engine light on? With the reduction in power it almost seems as though you've lost a cylinder. I'd check that all your spark plugs are firing. If they all are, I'd check compression. With all the shaking, I'd also take a look at the engine mounts.
Old 11-15-2009, 12:05 AM   #3 (permalink)
there's a good possibility you have bad plug wires. They usually cause misfires at app. 1800 to 21 or 2200 rpm under light acceleration, light load. nabowen
Old 11-15-2009, 12:50 AM   #4 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
My car shakes like a freaking tank & I drive a dodge neon >.<
I am 80% sure I have a vacuum leak & I also have a broken engine mount...
check those 2 things...
Old 11-15-2009, 12:55 AM   #5 (permalink)
The Neon - '00 Neon
House of Tudor
ACTUALLY, if you figure out what is wrong with your car PLEASE PLEASE PLEASE tell me what is was and how much it cost b/c I read the rest of your post and mine is doing all the same things...
it acts CRAZY between speeds 55+
the idle is crap, it jumps and dips
my cruise control randomly turns off
my car shakes (partly b/c of the broken mount)
so does it really sound like a bad vacuum line?
how much is that to fix?
Old 11-15-2009, 08:59 AM   #6 (permalink)
surly teady bear
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
If you have a vacuum leak open the hood with the engine running and you should be able to hear the hiss. once you locate it it will cost a couple bucks for the right size vacuum hose to replace it if needed.
Old 11-15-2009, 11:44 AM   #7 (permalink)
The Neon - '00 Neon
House of Tudor
Is there any way it could be the line that does my cruise control?
Old 11-18-2009, 11:37 PM   #8 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
1994, and a mitsubishi
try struts.
I have found that to be a problem. vibration has bearing smacking, shaking and seemingly normal otherwise is something else.
Old 11-19-2009, 04:06 AM   #9 (permalink)
I would look at the easier things first, like some of the other posters say.
I would think it might be a plug wire off or a defective sparkplug. But if that seems alright, take a better look at your distributor. If that checks out, you may be looking at a timing belt or chain.
Old 11-19-2009, 01:29 PM   #10 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Sounds exactly like what my van was doing when it had a bad spark plug wire. A bad spark plug or coil can do the same thing.
My Celebrity did it once too right after putting in new spark plugs. Turned out 2 of the new plugs had cracked insulators. NEW new plugs, and the problem was gone.
Winter daily driver, parked most days right now
Summer daily driver
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Electric Car Wind Generator Charger demo unit bennelson Fossil Fuel Free 12 04-28-2009 12:20 PM
Aero suggestions for my car atomicradish Aerodynamics 17 07-27-2008 03:29 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 10:37 PM
