Old 11-28-2009, 07:30 AM   #11 (permalink)
Flying is out of the question with eight people. One consolation, however, is that I get better than 200 mpg per person.
Old 11-28-2009, 07:33 AM   #12 (permalink)
Oh yes, thanks for that. It is 15,000 kms or about 10,000 miles. Nova Scotia is way out to the east of Maine, and we are going to Vancouver Island in the West. Also, we are going on a circle trip, down to NC. I did not give the full route, but you are right. It is not quite 10,000 miles. Sorry about that.
Old 11-28-2009, 07:38 AM   #13 (permalink)
Is is interesting what you say about mounting it toward the back. I played with that on previous trips and it did seem to make a difference. I got better mileage when it was mounted as far back as it will go rather than as far forward as it will go.
Backwards? That is interesting. It looks like it is designed to be aerodynamic. Is that just an illusion?
Old 11-28-2009, 08:29 AM   #14 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
It's stubbed on the back... you want a slope to the rear. The face of an object has a negligible effect on it's aero profile compared to the rear. The idea is rounded front, sharp rear, mild angle between the two. You want the shape of an object to train flow back to a closing point, not leave it opening as the flow trips from the edge of your object.
There are plenty of resources for aerodynamics here and all over the internets.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 11-28-2009, 09:05 AM   #15 (permalink)
I corrected the error about the distance in my original post, so thanks again for pointing it out.
Old 11-28-2009, 12:01 PM   #16 (permalink)
Originally Posted by Christ View Post
The cargo rooftop carriers that you get from sears, you should probably mount it backwards, right at the end of your vehicle. It might hurt a little less that way, by helping to train the flow down over the rear hatch of your van.
But, probably not. You'd almost be best off trying to take everyone's crap and making a boat tail out of it on the back window of the van, honestly. Might get a gain out of it!
The back of those cargo carriers is usually a pretty flat surface. I know people are fond of saying "it would be better backwards".... No it wouldn't, not when a sheer front surface is slamming into the air, causing it to fan out.
Would you say a Prius is more aerodynamic going backward? No, so why say it about any other Kamm shape?
This one might not be so bad backward
The Following User Says Thank You to winkosmosis For This Useful Post:
CROSS CANADA WITH 8 (11-28-2009)
Old 11-28-2009, 12:09 PM   #17 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Summer - '00 Cavalier Z24 Convertible
90 day: 29.82 mpg (US)
Send a message via AIM to brucey
Slowing down would save you the most.
A hitch rack box would make a negligible difference on a van, it might even help a bit.
A roof box and high speed is a disaster.
The Following User Says Thank You to brucey For This Useful Post:
Old 11-28-2009, 01:06 PM   #18 (permalink)
Might I suggest a small trailer instead? One with cargo box capacity has negligible drag - I used to pull one behind an 850 cc bike on long camping trips, and it was barely noticible. Other advantages:
1) It's not producing any extra aero drag, and might even help a van's aerodynamics.
2) It takes most of the weight off the van's suspension, so better/safer ride & handling.
3) It's a lot easier to load & unload :-)
4) If you want to make side trips, you can leave it behind.
The Following User Says Thank You to jamesqf For This Useful Post:
Old 11-28-2009, 05:37 PM   #19 (permalink)
Do you mean to say that it would be better? Mine is more or less shaped like the second one, although taller and wider and not nearly as long.
Old 11-28-2009, 05:59 PM   #20 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by MadisonMPG View Post
This is unquestionably the route you should take if you have the option.
Yes, it makes parking harder, and hatch access more difficult.
But it's by far the best way to to improve efficiency vs. a roof carrier.
Have you done the math to calculate the MPG penalty of your rooftop carrier? If I had to guess, I'd say it's in the range of 10-20% at typical freeway speeds.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Trouble-shooter's top question in '07? How to handle high fuel prices. MetroMPG General Efficiency Discussion 7 03-14-2011 02:37 PM
Newbie Question !! Next car opinion? chipX Aerodynamics 15 01-25-2011 12:16 AM
Question about HOW a car AC works... hondaworkshop Off-Topic Tech 15 06-13-2009 12:55 AM
