Old 06-29-2008, 11:36 PM   #1 (permalink)
Car Won't Start While Moving in Neutral Any Ideas?
My 89 Pontiac Grand Prix won't start while moving in neutral. In the driveway it will start in Park or Neutral with or without the brake pedal pushed and if the car is just barely moving it will start in neutral, but as much as 5 mph and it will not start. Not only that, but once it has gone that speed, it won't start in neutral even when I've braked to a dead stop. It has to go back to park to start. Does anybody have any idea what I need to be looking for? The Chilton book didn't give me any idea.
Old 06-29-2008, 11:46 PM   #2 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Do you mean it won't crank, or it won't fire up?
Old 06-30-2008, 12:01 AM   #3 (permalink)
It won't even crank. There has to be an override somewhere.
Old 06-30-2008, 12:26 AM   #4 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
I'm just guessing here but it sounds like the car is using a VSS signal to disable the starter while its in motion via the neutral safety switch. The easy fix for this would be to run a wire from the starter wire at the ign switch (thick yellow wire) straight to the solenoid (fused at the connection made at the ign switch for safety). Keep in mind that this will effectively disable the netural safety switch on the vehicle and will then allow it to start in gear so do that at your own risk.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 01:07 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 09:46 PM
I need a car, what should I get to start out with? OfficeLinebacker EcoModding Central 12 05-22-2008 04:20 PM
Why won't my engine start on neutral at 50+ MPH? blackjackel Hypermiling / EcoDriver's Ed 18 05-16-2008 10:14 PM
