Old 04-26-2017, 12:48 PM   #721 (permalink)
Originally Posted by Grant-53 View Post
If wind tunnel time is pricey look around for someone with a camera drone. You could do tuft testing on a lonely road with the drone.
That would require a functioning car - which would be a lot more work. If I can at least test the aero, I could make molds and new body panels that could be used on a much more conventionally built chassis. And possibly get to a working car with less time / money / effort.
Another way to go, that I have been thinking about, is to build a new prototype with the method used for the Trev:
https://teamtrev.com/
Which is a folded "box" of composite sandwich panels, with foam added on the outside. This is MUCH quicker and has much better 3D accuracy, and has structural strength built in.
Old 04-26-2017, 12:51 PM   #722 (permalink)
Camera drones are good for maybe 25mph. Racing drones are good for 120mph.
I suggest a camera on a tripod at the center of a 100ft circle. That way you can characterize cross-wind flows.
NeilBlanchard: I've watched the adventure over the years and wondered about starting over. That's a lot of work to just melt into a puddle, but you've learned a lot and I support your eventual decision.
I've thought about an Inrekor style chassis, but made with swing-door material.
http://ecomodder.com/forum/showthread.php/so-why-do-you-think-there-no-cheap-32312-5.html#post487108
PlyMetal™ Swing Door - PLYWOOD CORE WITH INTERIOR AND EXTERIOR ALUMINUM LAMINATES
Old 04-26-2017, 11:07 PM   #723 (permalink)
Convert the body to polygonal models of different sections then use Pepakura to make a folding pattern.
To achieve symmetry, figure out how to make a mirror pentagraph with a 1:1 ratio. Then you hand shape all of one side. Build up the other side with material thicker than needed everywhere. Trace the finished side with a stylus while a router mirrors the Y plane (in-out from vehicle axis) on the other side while moving the same as the stylus in Z and X planes. A 2 axis tilt on the stylus, copied by the router, would help reproduce finer details.
With a stylus and router bit of the same shape and the positioning correct so it's not carving too much or too little, it would make fast work of finishing a body plug for making molds.
In short, like a giant Copy Carver that works in more than two axes. If it fails, hack it up with a pair of axes.
Old 04-27-2017, 03:34 AM   #724 (permalink)
I'm not sure how the Pepakura Designer software helps with routering foam.
However the peel pattern it generates could substitute for the stage of hammer-forming sheet aluminum that Randy Grubb uses. Make a wooden buck that egg-crates together like he uses. Make one half, dissassemble and reassemble in reverse for the other half.
Old 04-27-2017, 04:42 PM   #725 (permalink)
I have been looking at some paper model software and the HPV Shell Design program of Wayne Shook at recumbent.com. The tub I might try to make from my stock of 9mm aluminum honeycomb (Testori America) per cut and fold and the skin from 0.062" ABS since I would not be making a mold.
There are new drone models coming out each year and our son just bought a DJI Phantom which goes right fast. When he gets proficient he could do highway speed camera work for tuft testing for say $200/hour.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
