Old 02-28-2010, 11:39 AM   #1 (permalink)
One Cold North Dakotan
Panther2k - '00 Grand Marquis LS
90 day: 23.56 mpg (US)
Sammy - '88 Samurai JX
90 day: 21.19 mpg (US)
Carburetor efficiency question..
Well here's my first and probably only post.
Now, I don't have the most efficient vehicle ever made, but I bought it because it meets 2 conditions..:
1)It's 4x4
2)It gets decent mpg
The Suzuki Samurai
In the summer I've been getting about 30 mpg on the highway and almost as good in the city. It's has a 2 barrel carburetor, with a single primary and a single secondary.
***So my QUESTION is this:
Will an equal throttle position in different gears (4th or 5th) ALWAYS equal the same mpg?
I'm wondering this because I'm thinking the higher RPM can suck the fuel/air in faster and even though the valve is open the same amount, it gets sucked through it faster, resulting in more fuel burn.
I also have a vacuum gauge ready to install. With this, will I choose 4th or 5th depending on the condition (hills or headwind) based on which ever gear gives the highest vacuum?
Thanks.
Old 02-28-2010, 12:12 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...simple answer: No.
...because the engine RPM's are necessarily different in different gears...and, the faster the engine turns, the lower it's fuel economy will be.
..."Rule-of-thumb" -- best FE occurs in the highest gear at the slowest engine speed that doesn't 'lug' the engine.
...a vacuum gauge is an excellent indicator to have and use!
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 02-28-2010, 12:23 PM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Clean Green Toaster Machine - '06 xB
90 day: 45.81 mpg (US)
What Old Tele Man said.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.4 mpg avg over 30,375 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
45.8 mpg over 2235 miles, 164% of '08 EPA
Old 02-28-2010, 12:24 PM   #4 (permalink)
Well it's hard to tell if I'm lugging a 1.3L that puts 40 hp to the ground! When I cruise at 65 mph in 5th gear, I'm doing 3600 RPM. It's not lugging, it's just suffering from sheer lack of power.
So a real life example..
65 mph, 5th gear, 3600 RPM, 3/4 throttle
65 mph, 4th gear, 4100 RPM, 3/4 throttle
Even though I'm going the SAME speed and have the SAME throttle position, 5th gear should yield higher mpg?
I use 5th gear on the highway 90% of the time, but once in a while due to the barrenness of ND, winds can get crazy high and the truck doesn't have the power to hold speed at 60 mph even when it's to the floor. So I drop it to 4th.. Usually it's not that bad, and to go 60 mph I keep it about 3/4 though.
After all this is said though, once I get the vacuum gauge installed, I should just go by which ever gear produces the most vacuum to hold the speed I want, correct?
Old 02-28-2010, 12:27 PM   #5 (permalink)
...beats walking...
...what does the vacuum gauge say at each setting?
...bet there's a measurable difference with the higher gear showing a lower vacuum number, indicating heavier "breathing"--an indication of better BSFC.
Old 02-28-2010, 12:35 PM   #6 (permalink)
Dunno, it's not installed yet.
Old 02-28-2010, 09:28 PM   #7 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
I have used a few samurais over the years, great little rigs but they do indeed suffer from a lack of horse power when runnin at highway speeds. With a webber carb nd 235/65s I was able to keep going on level ground at 70, on the first bbl in 5th any wind or uphill down shifting was pretty much required. My milage when in town was about 30ish till I moved to the bush then I was lucky to get 20mpgh. (4x4 engaged and slogging through dirt, snow, short trips and the like)
When cruising in 4th or 5th gear even with identical throttle positions you are sucking more air through at higher rpm which mean more fuel as well.
You can feel with the accelerator petal where the second bbl on the carb opens up ride wide open on the first barrel and let the truck do as best as she can, down shift when you have to and use the second barrel if that can't keep you moving fast enough.
Cal mini performance, petroworks, and rocky road outfitters have stuff that may help. a low rpm torque cam Will likely be high on my list for the next one. The help in fuel economy wont necessarily pay for a cam, but they do help in the off road drivablity department.
I am pretty sure that the 1.3 puts out about 65ish.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 02-28-2010, 09:56 PM   #8 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
is the carb progressive secondary?
if so, is it vacuum valve, thermal controlled?
if use of one barrel, yes you want the whistle of atomizing...and that also leads to a very decent surge into the second barrel. The samuri is not that old, I assume progressive.
30 is doing good. samuri with larger wheels still has low gearing, but it helps. and also, do not remove engine driven fan, that is a helper not a killer. the downdraft loves it. it is an "anti-thumper", carbs like smooth.
Old 02-28-2010, 10:11 PM   #9 (permalink)
Stock carb is progressive iirc
Old 02-28-2010, 10:19 PM   #10 (permalink)
I'm not too sure what you mean there. Can you rephrase it?
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Tires question RandomFact314 EcoModding Central 18 04-20-2009 11:30 AM
Prius Question Matt Herring EcoModding Central 13 07-24-2008 03:07 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
