Old 06-24-2008, 01:19 AM   #1 (permalink)
Lancer - '00 Lancer GLX
90 day: 30.28 mpg (US)
carburetor main jet screw and a/f screw
hi,
i am a user of a lancer glx 2000 sohc carb engine. i tried adjusting the main jet screw and a/f screw to the lean best idle.
i would try leaning out first the main jet screw, then adjust the a/f screw to compensate. this in turn would yield to lesser fuel delivery to the intake manifold.
would it hurt the engine if i do it this way? its like i am supplying less a/f mixture to what is prescribed by the manufacturer.
Old 06-24-2008, 08:23 AM   #2 (permalink)
Harebrained Idea Skeptic
The White Car - '84 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 535i
Last 3: 23.86 mpg (US)
You could certainly hurt the engine. Are you monitoring A/F ratios in any way? Trying to make a "lean burn" engine out of one not designed for it will only result in overheating and severe detonation.
Old 06-24-2008, 08:39 AM   #3 (permalink)
ok, here comes the confusion, that even i am confused with...
i am still running at an a/f mixture of approximately 14.7:1 as seen from the o2 sensor and emission tests. i do not experience preignition, knocking, pinging, and detonation or any signs of engine misfiring.
what i actually did is decrease the total amount of the a/f mixture.
let's put it this way "hypothetically". let's say my engine requires 5 grams of a/f mixture that is 14.7:1 to enter one cylinder to compress and burn. by adjusting the main jet and a/f screw appropriately, i decreased the a/f mixture which is still 14.7:1 to just 2 grams. take note that the grams that i am mentioning is just hypothetical.
will decreasing the total a/f mixture (even though 14.7:1 is maintained) hurt my engine?
Old 06-24-2008, 08:58 AM   #4 (permalink)
What you're saying isn't possible. If you are reducing the amount of fuel, you are increasing the A/F ratio. It's as simple as that.
However, if the engine has a "feedback" carburetor that is adjusted by a computer, you're probably only adjusting the absolute limit, which the A/F isn't reaching because the computer has sufficient adjustment left.
Old 06-25-2008, 10:02 AM   #5 (permalink)
ok, so what then can i do to improve mileage? that is besides changing my driving habits and tune up?
Old 06-25-2008, 01:36 PM   #6 (permalink)
Those are the two main ones, but there are plenty of other suggestions here on the board, such as weight reduction, aero mods...
