Old 06-22-2008, 12:09 AM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Cel 17 - Vss
Only comes on during engine braking, anyone know what might be up with that?
<3
Old 06-22-2008, 12:29 AM   #2 (permalink)
Red
Red's Avatar
Send a message via MSN to Red Send a message via Yahoo to Red
Wire grounding out?
Old 06-22-2008, 12:29 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Why would it do that while I was engine braking though?
Old 06-22-2008, 01:05 AM   #4 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
engine shifting over in one direction could short/ break a wire.
not saying that iss your issue. . .
6 speed ALH TDI
Old 06-22-2008, 01:15 AM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Nah, that's not it. I did all the wiring myself on it...might just rip it out and redo.
Old 06-22-2008, 02:06 AM   #6 (permalink)
Red
Red's Avatar
Yeah the engine moving around in its mounts could do it.
Old 06-22-2008, 04:23 AM   #7 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
Put a test light on your VSS and see if you see any changes during normal driving and engine braking. I believe the computer uses the fuel cut-off during engine braking because it combines the TPS readings with the VSS readings so that may have something to do with it, maybe the readings are off from normal and it only can see a descrepency (sp?) during engine braking.
Old 06-22-2008, 04:17 PM   #8 (permalink)
The way you test to see if the vss is working is to see if the CEL light comes on during engine breaking. In my crx the screw connection on the back of the cluster came loose and I got a CEL. Maybe that's the only way it can tell that you are not sitting still revving the engine
According to the manual you need to jack up the front wheels and rotate the front left tire to see if the voltage pulses between 0 and 5 Volts with the meter
on b10 yellow/blue and ground at the ecu. If your speedo is working then the vss is working and you must have a bad wire. Run an new wire from the supermid to the ecu?
The attachment is from the crx mpfi manual so it uses a different connection at the ecu for obd0
Old 06-22-2008, 07:22 PM   #9 (permalink)
reformed's Avatar
Money pit - '97 j30
Are you using the VX trans? This may not be the issue but I'm just brainstorming a little here... If you aren't using the VX trans then maybe the VSS in your transmission is operating in a different voltage range than in a VX trans and the VX computer sees this as a malfunction. If you are using a VX/CX trans then forget everything you just read here.
Old 06-22-2008, 07:42 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
I'm using an HF trans with a random vss not original to the car or transmission. It did this before the vx swap...just did it again so I did a little eoc and then the car wouldn't bump start back to life...I think the main relay must be dying.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
VSS, tach, injector signal logic wikityler Instrumentation 2 07-21-2008 12:02 AM
Decline in U.S. summer gas use expected for first time in 17 years SVOboy General Efficiency Discussion 13 06-03-2008 10:58 AM
EcoModder featured on Fox 17 / Grand Rapids MI? MetroMPG Forum News & Feedback 2 04-17-2008 12:39 AM
[CRXMPG Mailbag] SuperMID and VSS Issues with EF Civics SVOboy Instrumentation 0 02-03-2008 05:33 AM
