Old 05-03-2009, 08:20 AM   #1 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
Center caps fill-painted
Stock: Civic HX center caps not filled
I thought the "H" needed to be blackened.
Yes the wheels need repainting but that's beyond what I'm ready to do now. I do like the caps though. I used acrylic paint from a craft store.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 05-03-2009, 05:30 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
So you just painted it on with a brush?
Old 05-03-2009, 08:09 PM   #3 (permalink)
Hypermiler
brucepick's Avatar
Yes, brushed. Just let it fill the recessed "H". I had to wipe the high spots clean, that was the toughest part - wipe it without dragging up more paint from the recess. Let it dry (just a few minutes once I got the dilution right), then repeat a few coats as needed.
Yes, spray could give a cleaner surface. I figured shucks, it's black. If not glossy, perfection in the finish won't be an issue.
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 08:59 PM
When to Fill up trikkonceptz Hypermiling / EcoDriver's Ed 5 05-05-2008 09:14 PM
Solid wheel caps (moon discs - where to get?) NoCO2 Aerodynamics 48 02-12-2008 06:23 PM
