Old 01-13-2010, 01:46 AM   #11 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
Originally Posted by JasonG View Post
Combustion chamber, piston dome and ex valves helps if you're boosting and running lean. If you are doing a home-brew lean burn, it may save your engine.
For all around better fuel usage, spend the money on ceramic coated tube headers. The retained heat keeps the exhaust velocity up.
that is clever. some cars have metal covers all over the pipes...even black stove paint was smarter. that may have something cermical anyway...
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 01:53 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
