Old 01-07-2010, 05:04 PM   #1 (permalink)
rusty - '00 mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 zx10r
90 day: 37.84 mpg (US)
Ceramic coating the intake and engine block
and/or pistons and comb chambers.
Do you guys think it's a good idea? If so why and why not.
Thanks.
Old 01-07-2010, 05:22 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Coating the pistons and chamber will help, but probably not noticeably. However, coating might help you increase compression ratio which could have a larger effect on mileage.
I haven't heard of coating your block or intake, and I'm not sure why you would.
Old 01-07-2010, 07:55 PM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.26 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Combustion chamber, piston dome and ex valves helps if you're boosting and running lean. If you are doing a home-brew lean burn, it may save your engine.
For all around better fuel usage, spend the money on ceramic coated tube headers. The retained heat keeps the exhaust velocity up.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
The Following User Says Thank You to JasonG For This Useful Post:
dave77 (01-08-2010)
Old 01-08-2010, 12:25 PM   #4 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
You can also get a moly coating on the piston skirts that will reduce friction. Typically when the combustion chamber is done they coat both intake & exhaust valves.
It also makes it a good time to get a 5 angle valve grind on the exhause valves.
The Following User Says Thank You to DonR For This Useful Post:
dave77 (01-08-2010)
Old 01-08-2010, 01:57 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
nemesis -
This makes me think of the following scenario. I have an engine with 190K miles on it, so it's gotta be a bit worn. If I needed to do a rebuild, then maybe this would be a good thing to do *during* the rebuild. That way, in theory, I could beef up the engine to good or better than new.
CarloSW2
American Solar Energy Society
Old 01-08-2010, 02:01 PM   #6 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
i get what you're saying with the block and intake I think coating it would keep the motor heat in possibly and increase mileage
If you already have the motor out of the car it's worth a shot
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-08-2010, 02:07 PM   #7 (permalink)
Porshe - '06 zx10r
Heat is energy, and I am not filling the car up with gasoline to heat my engine compartment, plus the engine will stay hotter when it's off, so the warm up won't even be necessary.
Old 01-08-2010, 02:27 PM   #8 (permalink)
CM400E - '81 CM400E
There are much cheaper and better ways of insulating your engine if that is all you are looking for. Ceramic coating will actually not do a ton of insulating since the layer is so thin. You need something thicker if you really want to insulate it.
Old 01-08-2010, 02:34 PM   #9 (permalink)
Porshe - '06 zx10r
What do you think would work better?
Old 01-08-2010, 02:46 PM   #10 (permalink)
CM400E - '81 CM400E
Here is something an Insight owner came up with.
Randall's Insight - MIMA Honda Insight Modified Integrated Motor Assist
Efficient Engine Design ??? pgfpro EcoModding Central 110 02-12-2010 02:53 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 02:22 PM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 04:24 PM
