Old 02-08-2010, 09:06 AM   #1 (permalink)
chain adjustment?
I have just purchased a e-scooter a TS450LU. Any one out there that can tell me how to adjust the pedal chain? can't see a way to slide the wheel back. The shop that sold it to me can't tell me.??? Not sure how service will be from them. The chain falls off very easy and if I shorten the chain I belive that it is too tight. Need some help please.
Old 02-09-2010, 10:29 PM   #2 (permalink)
Is there a spot for a good old-fashioned chain tensioner? You could always try a sturdy spring, arm and roller, drill some mounting holes and let the tensioner take up the slack for you.
Does your e-scooter use bicycle chain or a heavier grade? If the chain were comparable to bicycle chain i'd just use an old derailler with the cable removed for your tensioner.
Old 02-10-2010, 07:42 PM   #3 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
sounds like they sold you a defective scooter, return it and ask for your money back.
Geo Metro plug-in parallel hybrid EV - in progress Coyote X Hybrids 138 12-29-2011 08:51 PM
Wheel bearing adjustment - another mod? Thymeclock EcoModding Central 16 02-05-2010 06:43 PM
tire size (Does ScanGauge have adjustment for different sizes) mcrews Instrumentation 2 12-15-2009 12:29 PM
Cycling Noob smsimpson83 Alternative Transportation 17 05-02-2008 06:49 PM
Daisy Chain vs ? WaxyChicken General Efficiency Discussion 8 01-18-2008 11:42 PM
