Old 02-05-2009, 10:26 AM   #1 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
Change "Custom" Screen?
I think I have it figured out, but I want to check in case I missed something. I want to adjust the "Custom" screen to display like this:
Code:
Instant MPG                     Trip MPG
Instant GPH                    Gals Used
Do do so, I change
Code:
void doDisplayCustom(){displayTripCombo('M','G',instantmpg(),'S',instantmph(),'G','H',instantgph(),'C',current.mpg());}
to be
Code:
void doDisplayCustom(){displayTripCombo('M','G',instantmpg(),'C','M',current.mpg(),'G','H',instantgph(),'G',tank.idleGallons());}
Is that correct? Are the stats called "Current" for "current trip"?
Old 02-05-2009, 04:54 PM   #2 (permalink)
Ziggy - '95 S6 Sedan
Manfred - '97 A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 A4 Quattro Avant
Sherman - '98 A6 Quattro Avant
Cab - '96 Cabriolet
This might do it:
void doDisplayCustom(){displayTripCombo('M','G',instant mpg(),'M',tank.mpg(),'G','H',instantgph(),'G',tank .gallons());}
The order of the values is Upper Left, Upper Right, Lower Left, Lower Right. There's only room on the display for a single letter label for the two right hand values.
I assume here that you want the instant information on the left and the tank information on the right. So, the 2 right hand values will be reset by pressing the left & middle buttons simultaneously. If you want the current trip instead of the tank, substitute current.mpg() and current.gallons().
Old 02-05-2009, 05:39 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
FYI, tank.idleGallons() will give you the number of gallons burned at zero mph for the tank. You might want tank.gallons()
Old 02-05-2009, 06:36 PM   #4 (permalink)
Instant I'd like on top, and Gallons on bottom. I didn't see tank.gallons when I was glancing over it at work - thanks for that. My 'guino display went blank on me on the way home today, so bust on the new tank of gas. I shut the car door, and an arrow "blipped" on the display in the left char on the top row, and then the display went blank. backlight still went up/down, but that's all I could do. So now that calibration is moot for this tank of gas, I unplugged it and will re-flash the code.
Oil change guys under-inflated my tires Formula413 The Lounge 26 06-20-2010 08:46 PM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Can I change the order of the menus? Wingmn OpenGauge / MPGuino FE computer 1 01-23-2009 03:13 AM
3000 mile oil change is a myth! SVOboy Off-Topic Tech 15 02-14-2008 03:43 AM
Article: CAFE Change Looks Likely SVOboy General Efficiency Discussion 0 12-05-2007 12:24 PM
