Old 02-12-2018, 04:49 PM   #21 (permalink)
order99's Avatar
This would work to change the oil in Mom's lawnmower: https://www.autozone.com/test-scan-a...tor/543344_0_0
I just need to purchase an air compressor.
Here's a manual at less than 1/4 the price: https://www.autozone.com/test-scan-a...tor/547010_0_0
And here's what I use -Dirt cheap, but takes a little longer (as in."pump to prime, go brew a coffee and come back in a half hour") : https://www.autozone.com/test-scan-a...ump/574855_0_0
Old 02-12-2018, 05:43 PM   #22 (permalink)
90 day: 29.44 mpg (US)
Sorry, I was joking. That pump costs a couple of times as much as Mom's mower did brand-new and then I would need the compressor. Since it did not have a drain plug, I ended up turning it upside-down, so a bulb siphon would definitely be better. I think I sucked on a clean tube until it started draining.
