Old 10-26-2009, 04:53 PM   #1 (permalink)
Charging Question
Hello ecomodders!
I'm new and was wondering if I could get some advice on a project.
Project details:
Series Hybrid Tour Boat-
turbo r-12x jetski engine
warp9 motor
12-14 48V50A Lifepo4 batteries
The requirements for this boat is to run on the electric motor for the 4 hour downstream tour, and then use the gas engine to get back upstream in an hour. It has to make 2 consecutive tours.
The plan is to charge the batteries off the engine's alternator. Perhaps with a voltage booster in between the alternator and batteries.
This is where I need advice.
1) Does this sound remotely feasible?
2) I'm a bit hazy on my recharging fundamentals... is it correct that Voltage input needs to be higher than that of the battery pack it's charging, and Amperage is proportional to charging time up to a certain max amperage(3C)?
3) Anyone know where to find high quality, high output alternators?
Sorry for the list of questions, I've tried searching and haven't found the answers yet.
Old 10-26-2009, 04:59 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Lemme be useful first.
1) Yep
2) Yep
3) Dunno
If the purpose of this hybridizing is to save on gas, you can't use the engine to recharge the battery. You'll use even more gas this way.
Old 10-26-2009, 05:06 PM   #3 (permalink)
The purpose is focused more on a quieter tour experience. Also on proof of concept. Anyone ever heard of an alternator producing ~30kW?
Old 10-26-2009, 06:20 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
30kw out of an alternator? sure, but they tend to be on top of wind turbine towers and weigh hundreds of pounds, you are going to need an engine that is putting out around 45-50hp to turn that alternator as well.
Old 10-27-2009, 12:53 AM   #5 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
You might consider starting with an existing power plant and series-parallel hybrid drive:
Specifications of an NHW11 engine and drive system:
  • 52 kW (70 hp)
  • 33 kW (44 hp) electric motor
The parts are available from Ebay but the control electronics will be a little tricky. They also have catalytic converter exhausts available so you won't be choking up the air on the river. For example, Ebay items:
390107196393 - transaxle
320048244146 - engine
370275265383 - inverter electronics
310133488258 - maintenance manuals
You also have the option of upgrading to an NHW20 drive system with a little more power. Fuel consumption will be impressive with either system.
GOOD LUCK!
Bob Wilson
Local record
A McDonalds to have EV charging stations bennelson Fossil Fuel Free 5 07-11-2009 10:19 PM
New England to develop Electric Vehicle Charging Infrastructure botsapper Fossil Fuel Free 1 04-07-2009 07:22 PM
EV public charging stations bennelson Fossil Fuel Free 10 03-10-2009 11:10 AM
EV Charging stations article bennelson Fossil Fuel Free 0 10-17-2008 12:51 PM
Question about EOC with an Auto... :confused: LastBoyScout Hypermiling / EcoDriver's Ed 20 08-30-2008 07:28 PM
