Old 07-10-2008, 08:53 PM   #11 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
FYI, the comments under this post describe the "puncturing the diaphragm" method. (Note: this only pertains to power brakes. Under no other circumstances should you puncture the diaphragm!)
EV Weblog: Larry's EV
Not endorsing the idea - just putting it out there.
Old 07-11-2008, 08:45 AM   #12 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
The "typical" way to quickly disable your booster is to undo the hose from the booster and plug it. The booster just won't have a vaccuum source and you won't have a vac leak. The "Proper" way is to take out the whole booster and upgrade MC. Removing the booster will remove a few rubber parts that you have to squish before pressure gets to the lines. Just removing the vac line means you are still squishing this stuff.
The hard part to get used to is that braking is now proportional to pedal PRESSURE, rather than pedal TRAVEL.
Instead of upgrading MC, you should also be able to alter your pivot point. Since this is not a racing application, you don't really care if the pedal moves 3-4 inches. For my track car when i do this, i will want about 0.5inches of travel to full lock-up.
Old 07-11-2008, 04:02 PM   #13 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
The pump you pictured is most likely AIR powered. (Venturi action)
The TDI has a cam driven Vacuum pump.
The Supra has an Electric Pump! It is however very small You could use 2~3 Should be able to buy them cheap; you can remove them and only loose your cruise + brakes under boost. (Who ever stops when they are boosting?)
6 speed ALH TDI
Old 07-11-2008, 09:36 PM   #14 (permalink)
Ah, thanks, dremd - I didn't think about a mechanical pump.
And I hadn't considered turbo cars needing an auxiliary pump. Interesting.
Old 07-16-2008, 09:23 AM   #15 (permalink)
The Hulk - '96 Aspire Base
90 day: 51.64 mpg (US)
Black Hole - '06 Rio LX
90 day: 39.16 mpg (US)
Send a message via AIM to steensn
You could always impliment and SCB system like we make for hybrids
I would suggest grabbing an electric vacuum pump from a diesel or even a lot of newer cars with cold start have them in it. Go to a GM dealership and get a part number for one of their vacuum pumps and see if there is a cheaper version somewhere.
2006 Kia Rio
1996 Ford Aspire
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
What is the best cheap car for Hypermiling? roadracer380 EcoModding Central 4 06-12-2010 01:50 AM
Active grill block idea holypaulie Aerodynamics 17 10-13-2008 09:31 AM
My First Electric car Experience WaxyChicken The Lounge 8 09-05-2008 08:46 PM
