Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 12-14-2007, 04:51 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Cheap way to patch a tube?
Are there any tricks or should I just buy a patch kit?
Old 12-14-2007, 05:04 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Not that I know of (which doesn't mean anything). I use sticky-patches for trail-side repair, and the regular glue kit at home.
I think the kit counts as cheap though. It's like 3 bucks, and there's enough stuff in it for half a dozen patches.
Old 12-14-2007, 05:06 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
I guess I'll have to get one, damn my luck. Didn't even ride one these two tires and both got flats (2 days after I put the air in no less).
Old 12-14-2007, 06:04 PM   #4 (permalink)
igo
igo's Avatar
Blue Saturn - '98 SL1 Base
90 day: 34.67 mpg (US)
Patch kits are like $1.99. Anyways, i heard you can cut up old inertube as long as you make sure to clean them and give the cut up tube a good sanding.
Old 12-14-2007, 08:53 PM   #5 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
I'm patch challenged. I have never been able to get a patch to hold on a road tube. I have had success with MTB tire I don't know if the pressure or what but I just carry spare tubes now on the RB.
"Judge a person by their questions rather than their answers."
Old 12-14-2007, 08:55 PM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
I bought a spare tube, went out and got 3, but 20 bucks later only one is holding air. Guy I bought the rims from never had a problem but thought it might be the powder coating flaking off. I'm about to play with them more.
Old 12-14-2007, 08:56 PM   #7 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
I've had success with rubber cement and a cut piece of a donor tube
Challenge me, or correct me, but don't ask me to die quietly.
Old 12-14-2007, 08:57 PM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
I wish I had some rubber cement...I wonder if that stuff I use for art whose name I forget right now might work...
Old 12-14-2007, 09:02 PM   #9 (permalink)
MechE
Contact cement would probably work too... Possibly even a liberal application of super glue. But really, a patch is just temporary until you get a new tube - in my opinion
Old 12-14-2007, 09:40 PM   #10 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
rubber cement, contact cement, any of it will work.
The trick to making a patch hold really really well is that you have to apply some serious pressure to it after it has been stuck on. If I'm at home I'll lay it flat and pound on it with a rubber mallet or something similar. If I'm on the side of the road I'll bash it between (whatever I can find) and the heel of my hand.
Oh, and make sure you're following the instructions as per the rubber or contact cement. Apply it to both pieces, then let it dry. Only after it's COMPLETELY dry do you stick them together.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
