Old 07-18-2009, 03:00 AM   #1 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Check my math?
I was thinking about the basic fuel consumption figures in the OM636 Manual I have... the max figure is 215g/HPh (Grams per HorsePower hour).
I wanted to figure out how much fuel (in gallons) it would take to make 1 HP for 1 hour, using this figure as the basis...
So I found that diesel fuel has mass of 3217.6 grams per gallon.
In order to find out how many gallons of fuel I should use to make 1 HP for 1 hour (1 HPh),
215/3217.6 = 0.0668199901
Is that right?
Reversing the equation gives me:
3217.6/215 = 14.9655814, which I take as being 1/15 of one gallon per HPh. Dividing 1/15 out gives me:
1 / 15 = 0.0666666667, approximately the same answer as above... so which way is the correct way to come about the answer?
(The first answer is "It doesn't matter, as long as it's right." But this doesn't hold true in math. If you got the right answer, by the wrong equation, it's still the wrong answer. You can't "stumble on" an answer in math, and I want to know the correct way to do it.)
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 07-18-2009, 04:50 AM   #2 (permalink)
Christ,
As long as your known numbers are correct, use your units to verify the equation.
215g/1 hph x 1 gal/3217.6g = .0668gal/1hph which is your original solution.
I guess we have to assume that the 215g/hph figure includes whatever the nominal efficiency is for the engine.
JJ
Old 07-18-2009, 10:21 PM   #3 (permalink)
215g/hph is the highest figure in the manual for fuel consumption. It's all I've got to go on.
Old 07-22-2009, 01:01 PM   #4 (permalink)
Bean counter$ !
My comment on the subject at hand is not the issue here. But I HAVE to say the line on bean counters is right on! The bean counters set GM up for a disaster ... beginning with R. Nader & the Corvair fiasco ... all the way to misreading the Toyota and Datsun invasion. Now, GM stands for Government Motors...and we'll see ( like who gets the next "bail-out" from the gov't? The gov't?).
We live in intere$ting times !!!
Old 07-22-2009, 02:17 PM   #5 (permalink)
Tasdrouille said it, I just quoted it. Thanks anyway.
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 42 03-28-2010 03:24 PM
Super efficient fridge - need math advice Cd Saving@Home 17 07-12-2009 11:16 AM
HELP! Check engine light - Loss of power bennelson Off-Topic Tech 28 07-07-2009 07:13 PM
volumetric efficiency and math bgd73 General Efficiency Discussion 1 06-27-2009 02:33 PM
Stimulus Check bah! Hand out scangauges instead. rsx2002 EcoModding Central 24 07-17-2008 11:28 AM
