Old 11-18-2008, 05:18 PM   #1 (permalink)
Tracy - '00 corsa
check out my new kammback !
its made of heat bended plexiglas from the local DIY shop and aluminium strips bent into hooks that anchor into the rear hatch.
i will test it soon. do you think the angle is too steep?
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 11-18-2008, 07:49 PM   #2 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
Yes, it would probably be better if it was less steep; but try it and see if it helps.
Old 11-18-2008, 08:19 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
modmonster -
I really like it because I think the rear visibility is important. I am not sure, but should the sides "come off" the side of the hatchback door? I ask because in my "Kamm-back plan to rule the world", that was my design assumption.
What is a DIY shop? I think I know what you mean, but I am interested in the one you went to.
CarloSW2
American Solar Energy Society
Old 11-18-2008, 08:50 PM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I think it may be too steep, yes. Did you by any chance see the "teardrop template" in my Kammback thread? It's a good starting place for figuring out the ideal shape/angle.
EDIT: here's the link to the post in question about the teardrop ... Project: making a permanent Metro Kammback extension
I really like the material choice. If I could do mine in clear plastic, I probably would.
Old 11-18-2008, 09:07 PM   #5 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
slightly too deep of an angle off the back, and the sides should extend past the hatch to the absolute sides of the vehicle to add maximum flow extension.
Looks great though, and even slight improvement is better than nothing.. (if it wasn't it would not be called slight IMPROVEMENT... correct?)
Old 11-18-2008, 10:05 PM   #6 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
COOL.
I think 'too steep' is a good place to start. I would suggest tuft testing while incrementally raising the trailing edge until attached flow is indicated. Then you know you're getting the most bang for the buck, as it were.
The only problem with that strategy is filling in the sides afterwards.
I also think plexi is the material of choice. Good job, modmonster!
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 11-18-2008, 10:11 PM   #7 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
I concur that plexi is the way to go. Time for some tuft testing though and then perhaps Kammback 2.0?
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 11-19-2008, 04:13 AM   #8 (permalink)
Tracy - '00 corsa
had a slight problem with moisture the other day. -dew on both sides.
Old 11-19-2008, 04:14 AM   #9 (permalink)
Tracy - '00 corsa
i had to put the support in the middle so no wipers im afraid.
Old 11-19-2008, 05:43 AM   #10 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
a had a corsa once but it met with a wall, still it intrests me how aerodynamic i might have made it if i'd still had it
since the prius is a bit of an icon when it comes to good earo i made a quick comparison between the two... the sketches are not to scale but it's interesting to see that the overall proportions of the two cars match quite well, only as as apparent in the first comparison to be as aero as the prius the corsas roof would have to drop considerably wich could make it look more like a CRX
when looking at the roofline curve and continueing prius style where the opel roof stops you can see it shoudln't be to hard to make a kammback that continues that line.
it would seem that your kamm angles down a bit to steep. you might get better results with changeing the angle wich couldn't be that hard to do i imangine.
also your car has these gentle curves at the back, generally a clear cut edge will promote cleaner saparation. perhaps small spoiler strips to the sides could cure this...
could make a difference in aero too
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 251 12-02-2011 01:24 AM
HELP! Check engine light - Loss of power bennelson Off-Topic Tech 28 07-07-2009 06:13 PM
Stimulus Check bah! Hand out scangauges instead. rsx2002 EcoModding Central 24 07-17-2008 10:28 AM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-30-2008 11:23 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 06:07 PM
