Old 09-04-2010, 07:16 PM   #1 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
Chevy hypes Eco Cruze oil-pump
...more info here:
"Efficient Oil Pump Helps 2011 Chevy Cruze Eco Achieve 40 MPG on the Highway" Green Car Advisor
Old 09-04-2010, 08:04 PM   #2 (permalink)
Zerohour's Avatar
Pooparu - '01 Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '011 Cooper
90 day: 36.4 mpg (US)
People Power - '86 Not Slim
90 day: 5.45 mpg (US)
Jesus Christmas. All I can say, is that will be one more headache for the owner 5 years from now.
Its a good idea, but honestly, I would like to point to an LT1 block and go look, see how the water pump is directly camshaft driven...and see how its right over the over the optispark ignition, on yeah thats a good one too. That least those were external. Brilliant ideas from GM, don't always live up to the hype.
Seriously, all they need to do is go to aluminium bodies, combined with fiberglass/Carbonfirber/Kevlar composites, and they'll hit 40MPG really quick. Not to mention start removing excessively waste like 20 way power seats, 10 speaker audio systems. Car manufacturing has really lost its way.
Old 09-04-2010, 09:32 PM   #3 (permalink)
...beats walking...
...hence the use of the title word "hype"...I rest my case.
Old 09-05-2010, 05:10 AM   #4 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Same engine, similar sized car on test.
No longer here. Bye, and good luck to all.
Old 09-05-2010, 10:43 AM   #5 (permalink)
1991 Metro 1.0 Auto - '91 Metro Lsi Auto
90 day: 38.87 mpg (US)
Actually it's not a bad idea, it's basically the same as most automatic trans pumps so I don't think there will be any reliability issues with it.
Conventional oil pumps have to be sized for the motor at idle but once RPMs start increasing the amount of oil pumped increases MUCH faster/more than the amount of oil the engine needs so they turn out to be very wasteful/inefficient designs that bypass a large percentage of their flow most of the time.
Old 09-05-2010, 11:19 AM   #6 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Irocz LB9
Last 3: 30.14 mpg (US)
I like part of the concept.
I'd like it better if it were electric, it had a back-up, was external to the engine, and easily serviced/replaced.
At least they appear to be trying.
Old 09-05-2010, 01:47 PM   #7 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Once again the old brass Model T shows the way...
splash oiling. No pump at all.
j/k. Oil pumps are good. This new one is probably good too.
Old 09-05-2010, 02:00 PM   #8 (permalink)
Arragonis's Avatar
Team m8
Or indeed in a more efficient package, the Austin 7 with 747cc and 2 main bearing crank and 'splash' (aka 'total loss') lubrication.
Old 09-05-2010, 03:20 PM   #9 (permalink)
Only thing I don't like is the use of vane type pump compared to other oil pump types like spur gears or Gerotor type .
there not as robust as those vanes need to slide smoothly all the time . Any type of particles will hurt it a lot more than other types .
Old 09-05-2010, 04:02 PM   #10 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Splash and total loss are two different animals.
The Radial engines in a WW2 B17 carried 35 gallons of oil per engine and the system was total loss.
Pop flew a B17 back from Berlin with a cylinder head shot off of one engine and it never ran out of oil.
A Briggs and Stratton 5 HP engine is splash fed. I guess you could say it was total loss as all the oil would eventually run out, but the engine would seize before than point was ever reached.
My engine design from 2006 only produced oil pressure when combustion and compression were engaged. When in flywheel mode, oil pressure was not necessary.
regards
Mech
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
2011 Chevy Cruze Eco / XFE will have 1.4 turbo, 42 mpg (US) hwy rating MetroMPG General Efficiency Discussion 174 02-24-2011 10:09 AM
Restore oil additive... suspectnumber961 The Unicorn Corral 43 05-14-2010 03:40 PM
2011 chevy cruze eco has automatic grille block.. mcrews Aerodynamics 8 05-06-2010 08:52 PM
