11-30-2009, 02:21 PM
Chevy Volt driven by ABG (and good video on Jay Leno's Garage)
Hi,
The good folks over at AutoBlogGreen have driven a pre-production Volt, and they are the first journalists to drive it with the ICE running:
Quick Spin: 2011 Chevrolet Volt charges toward production — Autoblog Green
Reason: fixed typo in title
11-30-2009, 04:13 PM
Pokémoderator
NeilBlanchard -
Neato. I like the air dam detail. It looks verrrrrry familiar :
It looks like it's in 3 parts. I wonder if it is spring loaded so it can collapse when you hit a curb.
CarloSW2
11-30-2009, 04:43 PM
Pokémoderator
Hello -
This is an interesting blurb :
When we first talked to GM about the Volt three years ago, the thought was that the engine would simply run at a constant speed to maintain the battery charge. As development has continued, that strategy has evolved. The output of the engine/generator is based on the needs of the battery and motor, not what the driver is demanding. As the level of the battery changes, the generator is controlled to provide the necessary, electrical output. The engine speed in turn is selected to maximize the load on the engine. An engine runs most efficiently at full load. If the electrical demand is low, a lower engine speed is used in conjunction with the generator control to get the desired load.
I was expecting a single-RPM engine.
CarloSW2
11-30-2009, 05:41 PM
Moderator
Originally Posted by cfg83
NeilBlanchard -
Our cars are starting to look normal again!
Now that this stuff is going mainstream, maybe my wife will let me put the airdam back on the Elantra...
Hello -
CarloSW2
Well, it's a good news it's not fixed rpm. It allows to pick up the most efficient operating point for every load level.
11-30-2009, 07:56 PM
Pokémoderator
Hello -
Accidently found this image :
This means the Volt is designed to ride about 2" lower than the Cruze.
CarloSW2
11-30-2009, 08:04 PM
Pokémoderator
Yes, you're right. It's just that I've been hoping that the "ideal" would be viable in the real world, aka an engine designed to run at a single RPM. They also ditched the 1.0 V3 Turbo in favor of the 1.4 V4.
[EDIT: V3 and V4 are the wrong term, I meant to say I3 and I4]
CarloSW2
12-01-2009, 12:27 PM
I don't think that has anything to do with ride height. It's just that the center of gravity is lower, presumably because of the batteries mounted low in the frame.
12-01-2009, 02:04 PM
#9 (permalink)
More reviews:
The National Post (Canada) has a review:
Exclusive Preview: 2011 Chevrolet Volt - Posted Driving
So does the LA Times:
Chevrolet Volt: A sneak peek at GM's plug-in hybrid -- latimes.com
I've moved this over to the "Hybrids" subforum. As much as GM is fighting tooth and nail to convince people (journalists) to not call the car a hybrid, it certainly doesn't fit in our Fossil Fuel Free section! Series hybrid EV is probably as close as it gets.
Apparently we can expect to see a video on Jay Leno's Garage too.
12-01-2009, 02:17 PM
#10 (permalink)
Coincidentally, the ride height is also about 2 inches lower than the Cruze.
Not disagreeing about the effect of the pack on C.G.
Of course these are both pre-production vehicles; no saying if their ride heights are definitely what consumers are going to see.
