Old 11-21-2008, 10:14 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
Question about full front air block
I know that the idea is to get a teardrop shape, but I am having a bit of a problem with my air dam. I have an indent on my front bumper for the license plate and it causes the air dam to curve in a little bit, almost like a dent.
What would be the consequences of having it be like that? I mean would it hurt more than help.... ?
The ideal air dam is on the left, and (almost) mine is on the right... (overhead view)
Old 11-21-2008, 10:17 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
It's prolly not that bad since air will just form a high pressure pocket there, right smarties?
Old 11-21-2008, 10:18 PM   #3 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
That's what I'm hoping, but with the MPG contest, I am nervous to test it....
Old 11-22-2008, 01:27 PM   #4 (permalink)
dent
I'm with SVOboy on this one,and the flat area may augment the stagnation pressure in a positive way,which would be even more important with the blocking as you've pictured.
Old 11-22-2008, 02:50 PM   #5 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Well, it's official. Rex was participating in "No-shave November" and now he has a full moustache...
Old 11-22-2008, 09:54 PM   #6 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
Rex wins Novembeard!
If you decide to eliminate the license plate dent, just put some washers between the bumper and air dam.
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
What color to paint my full front air block? Sean T. The Lounge 15 11-11-2008 10:06 AM
Grill block affected milleage mar5ka Aerodynamics 24 08-31-2008 10:17 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
