Old 09-19-2016, 12:03 PM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Chrysler aerodynamic "stow 'n' go" roof racks
Some friends recently got a Chrysler minivan, and I noticed it has pretty clever stowable crossbars:
The bars stow in the rails themselves.
And extra clever bonus points: no tools required!
I didn't get a side shot, but they rails are fairly low - profile.
I also noticed if you wanted to take the rail off completely, the nuts are easily accessible.
ID:	20570   Click image for larger version
ID:	20571   Click image for larger version
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (09-20-2016), BamZipPow (09-19-2016)
Old 09-19-2016, 12:50 PM   #2 (permalink)
That's neat. Thanks
Old 09-19-2016, 12:51 PM   #3 (permalink)
Dark Egg - '12 VW Touraeg
They are great. Even better then a rack with the bars removed as they are much lower profile when stored. Then they are always there if you do need them. When we got our van used I was thinking there was something missing, I thought maybe the knobs were to remove the rails so it tried but instead found the crossbars.
Old 09-19-2016, 01:44 PM   #4 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
As an added bonus, they've got slots in the verticals to run a strap through and along the bottom. It's easy to use and solid.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
Old 09-20-2016, 12:53 AM   #5 (permalink)
So the rail pivots 90°? Overall shape is square?
If you lay a level or straightedge on it, how much crown side to side? Front to back?
My neighbors park a Saturn coupe right outside my window. I notice the bottom of all the windows lies in a plane. (There is a little crown in the hood to hide the wipers) It occurs to me you could cut the top off one and graft it into the roof of a box van or short bus and have a teardrop bubble top. With a sunroof.
Old 09-20-2016, 09:26 AM   #6 (permalink)
Rat Racer
The crossrails are removable and stow in place, embedded in the side rails. They don't add any frontal area when stowed, except maybe the wing nuts.
Old 09-20-2016, 09:33 AM   #7 (permalink)
It's not quite square. The distance between the anchor points athwartships is slightly less than the measurement fore & aft. Because the "feet" of the crossbars are bent/angled down when in use and then made straight out for stowing.
aerohead (09-20-2016), freebeard (09-20-2016)
