Old 03-31-2015, 08:56 PM   #1 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Circuit to translate MAP signal to boost gauge?
Anyone have a clue how I'd tap the MAP signal on my TDi to get a real time reading of manifold pressure in a convenient little gauge?
I don't wanna buy an analog boost gauge. They're entirely too expensive.
Old 03-31-2015, 10:42 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Buy a cheap pressure gauge!
Surplus Center
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 04-01-2015, 04:44 PM   #3 (permalink)
There are several cheap boost gauges on eBay as well, just didn't wanna get something that'll crap out quickly and also thought it might be neat to see what the MAP sees in real time.
Old 04-02-2015, 01:51 AM   #4 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
Sure, just put a VOM on the signal line.
1998 LX with a full HX swap + VX transaxle.
Old 04-02-2015, 02:51 AM   #5 (permalink)
Send a message via MSN to markweatherill
I used one of those LED oxygen sensor gauges and a potentiometer to drop the voltage from the 0 - 5V of the MAP sensor down to the 0 - 1V for the gauge. It works very well!
Old 04-02-2015, 11:13 AM   #6 (permalink)
That's actually a very good and creative way to do it but the o.p. Indicated they didn't want to spend a dime.
Old 04-02-2015, 06:04 PM   #7 (permalink)
In another thread I have posted a simple circuit that does this. Yes, it works! <$20. The proviso is that the MAP signal puts out a 0-5V signal.
An alternative is to connect the voltage divider to a cheap digital multimeter (volt meter). I can buy these for <$5.
Use the voltage divider to avoid shorting the MAP signal through the (1M ohm impedance) meter and to scale the signal from 0-5V to the units you want to see.
The Following User Says Thank You to Occasionally6 For This Useful Post:
Christ (04-03-2015)
