Old 08-20-2009, 01:09 AM   #1 (permalink)
OldertechGuy
Scott'sTxVx - '92 Civic VX
90 day: 48.7 mpg (US)
Civic 5th gen. speedometer
Our second VX, the 1992, is having the wonky speedometer, this time with only 150K. Last time we went to the junk yard and they brought a whole speedometer cluster in from another yard. Cost too much.
Question: Has anyone repaired these by swapping out parts? I see lots of auto speedos on eBay, but I'm wondering if just the speedo head unit can be swapped between the auto and stick car?
Has anyone had success at just swapping out just the circuit board at the back of the speedometer?
Thanks,
Scott
Old 08-20-2009, 07:11 AM   #2 (permalink)
basjoos's Avatar
Aerocivic - '92 Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Civic CX
90 day: 72.29 mpg (US)
The speedomoter on my car (92 CX) stopped working twice. The first time it (the speedo needle was totally dead) was a bad connector on the sending unit on the transmission. Some contact cleaner sprayed into the opened connector fixed that problem 180,000 miles ago. The 2nd failure (the speedo needle would respond to speed changes, but was spending most of its time at 6 o'clock on the speedo dial) it was a cracked solder joint at the base of the one of the long connector pins that attach the front display part of the speedo unit to the back circuit board. Reheating the solder joint fixed that problem about 100,000 miles ago.
aerocivic.com
Old 08-20-2009, 10:02 AM   #3 (permalink)
OldertechGuy
Solder joints
Those darn solder joints. Thanks for the tip. I'll get into mine and resolder them and hope for the best.
Old 08-20-2009, 09:58 PM   #4 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 43.34 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
If it comes down to you replacing the speedometer, it can be swapped from the clusters between the Auto and Manual cars. Once you pop off the clear plastic front of the cluster and take of the black plastic cover (where the idiot lights are) there are three screws holding in the speedo from the back. Just swap as needed to your original cluster.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 08-21-2009, 09:21 AM   #5 (permalink)
OldertechGuy
speedo
Tom,
Good info to know if I find a cluster from another type of car. How is your new engine doing?
Scott
Old 08-21-2009, 04:58 PM   #6 (permalink)
That VX guy!
TomO's Avatar
Glad I could help out, there may even be a DIY thread with piuctures somewhere on Honda-tech to help out more with visuals.
The new motor is doing great. It'll be even better once I get the oil pan gasket to stop leaking, lol.
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 374 Yesterday 09:50 PM
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 57 12-31-2011 10:11 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Largest Tire Diameter on a 6th Gen Civic (for lower RPM) UnCivic EcoModding Central 41 12-07-2009 01:41 PM
FS: Carbon Fiber Hatch for 5th Gen Civic trikkonceptz For Sale 8 06-04-2008 05:40 AM
