Old 09-30-2012, 11:18 PM   #11 (permalink)
Vader - '15 Dodge Grand Caravan
90 day: 23.13 mpg (US)
Cmax - '13 Ford Cmax SEL
90 day: 40.92 mpg (US)
Originally Posted by vskid3 View Post
Are you sure the 30-32MPG ones weren't the EX trim? They have a more powerful engine and shorter gears.
Well For example I've looked at two '98s (both automatics) that were lx's and both sellers said they got 32-33 tops.
I plan on looking at a '95 ex 1.6 litre automatic (with a sunroof haha) and the seller says gets mid to upper 30s and has pulled 44-45 at times on the freeway. From what I've seen the older models are lighter (and maybe taller gears?) thus giving better mpgs?
For being a small car I don't see why most Civics don't all pull at least 38-40 mpg minimum on the freeway.
Old 10-03-2012, 02:54 AM   #12 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by bestclimb View Post
92 would be the first year of 4th gen, 91 is last year of the "squareish" body style of the 3rd gen. They are good cars too, but they have kind of an odd fuel injection system.
You've got the generations wrong. 1984-1987 is the 3rd gen. 1988-1991 with the odd dual-injector fuel system is the 4th gen.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 10-03-2012, 02:01 PM   #13 (permalink)
darcane's Avatar
When I was looking for a Civic, I limited my search to a '96-2000 HX manual, as they are the most efficient that is OBDII.
Then I figured I'd also look at DX Coupes and CX Hatches as well, since they are almost as good.
Then I found a great deal on an '01 HX. Turns out, I shouldn't have left them off my list. I am still learning the car, but easily pulling high 40's for mpg without EOC or any of significant mods. I would leave '01-05 HX (and maybe DX/LX as well) on your list.
Certainly no EX or SI though if you want economy.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Ryland (10-03-2012)
Old 10-03-2012, 02:14 PM   #14 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
your right, apparently, I can't count
Fixed my previous posts
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 10-03-2012, 02:21 PM   #15 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Either 5th gen (92-95) or 6th gen (96-00) with a stick shift. Avoid EX / Si. Vx / Hx if you can find one, but the others do just fine. 96+ has OBD-ii for a Scangauge / Ultragauge. These cars have a LOT of potential by simply adjusting the driver, guided by the gauge.
Old 10-03-2012, 03:01 PM   #16 (permalink)
darcane's Avatar
I would ignore what most sellers say they get for fuel economy and worry more about which model it is. Most (all for many years?) Civics with sunroofs are EXs and you will have a harder time getting high mpgs out of one, so for me a sunroof was a dealbreaker. Having an automatic will also make it more difficult. Compare EPA rated fuel economy to figure out what models you want to look for: Fuel Economy
Also be wary of swapped motors and extensive mods (i.e. replacing exhaust on an HX can prevent you from using Lean Burn). There are a lot of hacked up Civics out there.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 10-03-2012, 07:12 PM   #17 (permalink)
I will soon be taking a close look at a '98 lx (no sunroof) auto. Wife can't drive a stick so I have to have an auto.
Yes I'm plugging every car I find into the fuel economy website. If I can get this lx for a good price, I'll use the methods learned here to max out the mpgs. I would think I can get close to 40 on the freeway?
I know its apple to oranges but my old '82 Ford Escort (carb'd and no computer)with automatic was getting mid to upper 30s on the freeway back in college.
Old 10-04-2012, 09:17 AM   #18 (permalink)
Hypermiler
Wagons
My DX can do low 40's mpg with the cruise set at 65. (at least, it could a few years ago. I get better numbers myself than cruise can)
Old 10-04-2012, 01:43 PM   #19 (permalink)
How much heavier is a '98 lx 4 Door vs a same year 2 Door dx?
Old 10-04-2012, 02:55 PM   #20 (permalink)
darcane's Avatar
Just under 100 lbs.
http://en.wikipedia.org/wiki/Honda_C...xth_generation)
7th Gen ('01-'05) Sedan is only about 40lbs heavier. If you want real light, go for a manual CX hatchback at 2200lbs.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
