Old 08-28-2015, 08:06 AM   #1 (permalink)
Needs More Duct Tape
MPGomatic's Avatar
Slambo - '99 Honda Civic HX
90 day: 44.21 mpg (US)
Civic HX Lean Burn - Skip Shifts
Skipping fourth gear just might be my biggest d'oh/aha/duh moment.
3K shifts into second, third, and then into fifth. The engine hits the right rev point, and with the longer shift motion the lean burn wuuuuh is audible, then the glide …
I dream about a running on a track where I could test this repeatedly to gauge the benefit. Run up to 50 10X through all the gears, then do it again 10x, skipping fourth.
Ain't Fuelin' - The Beater Build Show :
https://www.youtube.com/playlist?lis...R754kIg_V8Aahm
Old 08-28-2015, 10:47 PM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I shift at 2K.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
MPGomatic (08-29-2015)
Old 08-29-2015, 06:48 AM   #3 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I don't have LB or anything like that, but my best tank was recorded shifting 1-3-5 at 3K rpm. The second tank using the same method wasn't as good, but the third (current) tank is looking good.
Since I P&G EOC a lot, I figure if nothing else it helps reduce wear on the various shifting components.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
