Old 03-04-2010, 07:29 PM   #11 (permalink)
tim3058's Avatar
Project-Civic MPG - '93 Civic DX/VX swap
90 day: 47.04 mpg (US)
Silverado - '07 Silverado 1500 LT
90 day: 14.52 mpg (US)
Civic II - '07 Civic EX
90 day: 31.4 mpg (US)
Silver Bullet - '86 Camaro Z28
90 day: 19.74 mpg (US)
Yep, gauge shows its just about exactly 6" Hg to hold lean-burn. My car has had a real hard life, 55 tank mpg is downright incredible, not likely to occur on mine anytime soon. I filled up tonight, tank mpg was 49.00... a record for me, but not sure if 86 octane had anything to do with that, more likely trying P&G did it.
Old 08-29-2010, 08:07 PM   #12 (permalink)
lean burns quicker and thus internal engine pressure is much higher. My thinking is sure ethanol has higher octane, this just lets big oil use less octane boosters in plain jane fuel. My HX lean burn lost about 15% or more when ethenol was introduced into Texas, the MPG loss is even greater with lower octane fuel. yes my car is in perfect shape, yes I keep pen and paper of every fill up. I've gone from about 43 MPG to 36 MPG on cheap stuff, 38 or so on 93 octane. The car does ping with the advance I run on cheap stuff, if I set the ignition advance to factory spec MPG takes even a bigger dive. Ethanol was a big downer for me and my HX.
Question for people with a ScanGauge, does it show you when the car is in leanburn? Most foreign cars have a MPG light that lets the driver know but it does not come on a US spec HX or any other lean burn US spec car that I know of... bummer.
Old 08-30-2010, 12:56 PM   #13 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...I watch the "instantaneous" MPG numbers, when they suddenly jump from 35-40 MPG up to 50-55 mph during normal, level, driving, I assume my 1.8L Vibe engine with SIDI has computed it's OK to run lean...and is doing so.
Old 08-30-2010, 10:36 PM   #14 (permalink)
redyaris - '07 Yaris
90 day: 47.98 mpg (US)
Gray - '07 GS500 F
Motorcycle
90 day: 70.4 mpg (US)
KLR - '07 KLR650
Last 3: 62.78 mpg (US)
What I was told in trade school was that regular has more energy and a higher rate of flame travel. Premium fuels have less energy and a lower rate of flame travel; less propencity to knock. Alcohole in fuel improves completeness of combustion. Alcohole does have less energy than gasoline which may be the cause of loss of fuel economy. I suspect that how the engine responds to E10 fuel is a function of wheather the engine was designed with that fuel in mind.
Old 08-27-2011, 10:14 PM   #15 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
resurrection here.. but maybe Tomo knows? I just got a used Crane Hi-6 CDI system for my lil EG Vx with external Crane coil. It made his idle much smoother and stuff, but i think he only got 1-2mpg increase..which was negated by him driving faster! Will this be bad for the VX since I have lean-burn Fedal ECU? I'm using NGK sparkplug wires... and Iridium plugs. Perhaps a step colder heat range if I use this CDI system?
thanks for input guys.
PS. with some 14" 185 tires in front, 13" VX stocks in rear.. I'm getting about 40mpg with majority freeway driving. I try to keep it under 70mph w/VX 5spd.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Hydrogen Generator Experiment willy57 DIY / How-to 473 03-04-2011 02:29 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Fooling the ECU to burn lean... metromizer EcoModding Central 32 01-04-2009 04:26 PM
