Old 03-23-2010, 04:02 PM   #21 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
At least in 1996 and older civics the ECU only knows if the car is in revers or in 5th, it keeps track of if the car is moving while in gear, the engine speed but the ECU does not have a clue otherwise what gear you are in.
Old 03-24-2010, 03:32 AM   #22 (permalink)
Not according to the data the code gurus have extracted on pgmfi.org, there is a table - 1-5 gears that the ecu refers to so it knows what gear your in, but I believe 5th was the same correction as neutral? This is regarding obd1 code, but also, all code is not the same of the ecu variants. I shouldn't have mentioned it. A stock engine could probably care less.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
1992 Honda Civic VX for sale. Boston MA. Stock, factory AC, VX rims, new tires brakes civicvx For Sale 9 12-02-2011 09:47 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Looking at buying a civic vx. FE question yoshimitsuspeed General Efficiency Discussion 2 07-23-2008 06:50 PM
