Old 05-26-2010, 02:27 PM   #1 (permalink)
Civic VX Cali to Fed ECU Question
Hey everybody, I was hoping someone could clear me up on my cali to fed swap Im trying to do on my vx. I (luckily) have a 92 civic, so all I need to do is swap out the ecu and I should be good to go. I found an ecu on ebay cheap but it has the serial XXXXX P05 A02, will this work for my 92? Thanks!
Old 05-26-2010, 03:20 PM   #2 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
You need a P07-A00/A01 ECU to take advantage of the 5 wire O2 sensor...You do have the 92 cali model that has the 5 wire O2 and P07-L00 ECU in there now, correct?
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 05-27-2010, 04:18 AM   #3 (permalink)
Yes it is the cali model with a 5 wire, but the ECU serial is scratched off. I took a quick look but its dark now. Tomorrow Ill take out the ECU and give it a better inspection. Just got some VX wheels today!
Old 05-27-2010, 10:26 AM   #4 (permalink)
That VX guy!
TomO's Avatar
Congrats on the wheels.
You can take off the top cover of the ECU and the part number is usually on a sticker on the long gray connector on the top.
Old 05-27-2010, 02:15 PM   #5 (permalink)
Well in the daylight I could see that my ecu is a P07-L00, but the serial was covered in some nasty grime (probably from my girlfriends feet).
So this ecu won't work?
94 95 Honda Civic VX 1.5 Liter 5 SPD ECU ECM Computer: eBay Motors (item 120574803023 end time Jun-01-10 18:49:54 PDT)
Thanks I appreciate it.
Old 05-27-2010, 02:42 PM   #6 (permalink)
That VX guy!
TomO's Avatar
Originally Posted by jttriesch View Post
Nope, sorry that ECU won't work with the D15Z1. You'll need one of THESE in order to work with the D15Z1.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
Honda Civic VX question (egr black box) vtecn8ive General Efficiency Discussion 4 12-10-2010 09:55 PM
Civic Vx engine question. stock exhaust manifold vs. stock exhaust manifold vtecn8ive DIY / How-to 3 07-12-2009 01:07 PM
Looking at buying a civic vx. FE question yoshimitsuspeed General Efficiency Discussion 2 07-23-2008 06:50 PM
newb intro and question about civic hb vx reformed Introductions 9 01-29-2008 11:28 PM
