Old 10-02-2008, 12:33 PM   #1 (permalink)
the firefly - '91 Firefly Base
Last 3: 50.5 mpg (US)
White Lighting - '94 Civic HB VX
90 day: 48.65 mpg (US)
Civic VX & CX Spark Plug Gap
I have been doing some research into Platinum and Iridium spark plugs for my VX, unfortunately I am coming to realize there are none made
However in my search I have found that the Denso website (DENSO SPARK PLUGS)
Has the plug gap for the D15B8 (CX) and D15Z1 (VX) @ 0.032" instead of the regular 0.044" for pretty much every other Honda Civic D series engine, except for the GX which is a natural gas D Series engine that runs a compression ratio of 12.5:1 !
NGK has the gap @ 0.044" for the CX & VX.
I also checked plug gap on a 1988 Toyota Celica All Trac Turbo is 0.032 on both NGK and Denso (O.E. for Toyota)
A regular 1988 celica is a 0.044" gap
To sum it up I believe that Denso has spec'd a tighter gap on the VX, CX, and GX is because of high EGT in running Lean Burn mode and Natural Gas in the GX's case.
I only have 10k KM on a set of NGK's in my VX which I gapped @ 0.044 but I may check my gap and regap if necessary on the low side of 0.044"
Cheers!
Old 10-02-2008, 01:25 PM   #2 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 48.27 mpg (US)
The Family Cruiser - '03 Odyssey EX-L
90 day: 15.89 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
I've always run NGK-V power plugs (OEM) in my VX and gapped them at the standard 1.0mm (±.1) with no problems.
I wouldn't recommend running platinum or iridium plugs in the VX as they have issues with the heat generated from lean burn. not to mention, those type of plugs don't even really run in the proper heat range for the VX ZFR4F-11
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 10-02-2008, 01:47 PM   #3 (permalink)
I have heard some horror stories about Bosch Platinum plugs breaking down and loosing a side or ground electrode. Although I did run Bosch +4 Platinum plugs in my Escort 1.9 EDIS engine and it seemed to run alot better.
When I first bought my VX some silly dilly had ZFR5F-11 plugs in her and a 1/2 clogged PCV valve, the cat also was completely plugged.
Old 10-02-2008, 02:39 PM   #4 (permalink)
That VX guy!
TomO's Avatar
Originally Posted by flydude1221 View Post
I have heard some horror stories about Bosch Platinum plugs breaking down and loosing a side or ground electrode. Although I did run Bosch +4 Platinum plugs in my Escort 1.9 EDIS engine and it seemed to run a lot better.
For some cars those fancy plugs do work better
you wouldn't believe how common that is for the VX. Mostly due to the parts store's computer not having accurate information. My VX ran like complete dookie when it had the 5 heat range plugs in there from the previous owner. The EGR system was clogged as well as the Cat Converter was falling apart. the Previous owner told me that he usually got 260 miles out of a tank when he owned it.
DIY - Spark Plug Indexing SVOboy DIY / How-to 41 05-23-2009 05:07 PM
Civic VX wheels or aftermarket? travr6 EcoModding Central 6 09-30-2008 04:32 PM
cx conversion to vx model chris_marsho Off-Topic Tech 0 07-26-2008 12:57 PM
Civic VX VIN Info TomO Off-Topic Tech 0 01-25-2008 02:38 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 0 11-14-2007 04:57 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
