Old 12-29-2012, 04:33 AM   #1 (permalink)
Classic VW "aero" trunk
Automotive | Modern Mechanix | Page 4
OK, I looked, then looked, then looked some MORE and can't find the post where aerohead mentions this. So here it is in a new thread.
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
Dawie (01-08-2013), freebeard (12-29-2012), ron (12-29-2012)
Old 12-29-2012, 12:17 PM   #2 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
thanks Frank Lee I have a 55 vw Not Running presently but that trunk would look sweet on it . now I have to locate one or fab one
Old 12-29-2012, 12:45 PM   #3 (permalink)
The PRC.
Link to article here
LUGGAGE RACK for Volkswagen | Modern Mechanix
The Following 3 Users Say Thank You to Arragonis For This Useful Post:
aerohead (01-05-2013), cfg83 (01-05-2013), Sven7 (01-05-2013)
Old 12-29-2012, 02:43 PM   #4 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
i wonder how adding 110lbs plus behind the rear wheel in rr car changes it's "throttle steering" around corner.
Old 12-29-2012, 04:55 PM   #5 (permalink)
That's a very interesting accessory, Frank. I suspect 110lb is the capacity, to weigh that empty it would be made of 1/4" plate metal.
Look at this:
Even people who *are* thinking about the aerodynamics use those square end caps and don't think about the air flowing off the drip rail.
I looked at something similar. I use the '58 Canadian Beetle as a 'chicken coop' to store bumper and seats, and it has this cargo pod on top.
I positioned it as a boat tail, replacing the engine lid, to see how much I'd have to chop out for engine clearance
I forget that angle but it looks like ~22.5° to me now. It would need a pie-cut to give it adequate plan taper; something I haven't chosen to do yet.
Ron -- What will it take to get it running?
Old 12-29-2012, 05:17 PM   #6 (permalink)
1/4" steel plate weight per sqft is 10.20lbs.
ps. what makes it a canadian model?
edjumicated guess would be 184 lbs in 1/4" plate; not including brackets
Old 12-29-2012, 07:08 PM   #7 (permalink)
ron
has a rebuilt short block and I just need to reassemble that and hang the engine tin,small rust out on drivers side door pillar have that repair panel as well, the body only has 2 bolts holding it to the pan so .bottom line is if I got after it 3weeks to get it running and if I do a full bodyoff myself a year. interior paint is perf! Ultramaroon ;o)
Old 12-29-2012, 10:50 PM   #8 (permalink)
baldlobo -- Ah well—I was going to change that to 1/8" and didn't. If I had we would pretty much agree.
On the Beetle's bona fides: Any VIN number would have been in the front spare tire well, or on the floorpan. Those are both gone. It has a combination of the big back window with European turn signals (the empty semaphore turn signal pockets).
In case you didn't know it was purchased as a donor car to build the model in my profile picture. Which was painted first. Compare the purple tops, it seemed like it was meant to be, ten years ago. Now I'm starting to wonder.
ron -- Ultramaroon!
Old 01-05-2013, 04:15 PM   #9 (permalink)
bingo!
Originally Posted by Arragonis View Post
These are the images I have.Popular Mechanix may have ben a sister publication,as I believe that this is where my photos originated.I think it is 1955.
Thanks!
