07-30-2017, 04:17 PM
Clean vs Dirty car aero
I have heard that a dirty car gets better mileage than a clean car because the dirt creates a rough surface, kind of like a golf ball. But Mythbusters tested that and found thhat a dirty car reduces mileage, but then again they sprayed a half inch thick mud coating on it, which is not at all indicative of a "normal" dirty car, unless you go offroading lol. What do you think, and how big could the difference actually be? Thanks
The Following User Says Thank You to EcoCivic For This Useful Post:
07-30-2017, 04:57 PM
You'll get a lot of suppositions with a question like that...but hopefully someone comes along with some hard evidence one way or the other.
07-30-2017, 05:15 PM
I'd guess any aero gains are offset by losses caused by extra weight.
07-30-2017, 06:40 PM
Consider safety instead. Bright & shiny seen better by others.
Glass so clean in & out that new cars look bad.
Vision by others::Vision by driver.
07-30-2017, 09:11 PM
I don't think that the dirt weighs that much lol. But then again the difference in aerodynamics would not be much either.
07-30-2017, 09:34 PM
I don't know, I removed a couple hundred pounds of dirt from my company's backhoe yesterday just so I could service it. LOL
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
07-30-2017, 10:52 PM
A few years ago one of the world rally championship cars had the dirt they cleaned off it after 1 dirt stage weighed. It came in at 23ish kg if I remember right.
07-31-2017, 01:33 AM
Depending on the part of the world/ country you are in ,not washing the road grime off is a shure way to get rust started and that will cut your mileage and safety.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
07-31-2017, 11:19 AM
#9 (permalink)
Authoritative enough?
Originally Posted by aerohead
surface friction drag
Skin friction drag on a car is associated with air viscosity and local pressure.The car could be made of glass and have no lower drag than if painted with flat,camo paint.The only way you can reduce this friction drag is to not drive the car.
Permalink #26 in Clean vs Dirty Car / Much difference? in 2015.07
08-05-2017, 12:35 PM
#10 (permalink)
clean vs dirty
Aeronautical engineer and creator of the Litestar/Pulse,100-mpg vehicle of the early 1980s claimed Cd 0.18 'clean' ,and Cd 0.20 'dirty'.
It suggests that the vehicle had a laminar body.
Sighard Hoerner,who was with Messerschmitt in WW-II,claimed that the rough,olive drag,flat-primer-like paint on their fighter aircraft made no difference to performance.
Rough,clay,full-scale wind tunnel models appear to generate the same Cd as a production,OEM,lustrous paint-finished model of the same car.
