Old 05-26-2009, 02:10 PM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
cleaning up oil spills
Not that I eeeeeeeeeever spill any oil, but how do you guys clean up oil spills on your driveway?
Old 05-26-2009, 03:00 PM   #2 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Cat litter crushed into it or floor dry. Then sweep it up and save it in an empty 5 gallon container to re-use on the next oil spill. That floor dry stuff can absorb a lot of stuff!
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
Old 05-26-2009, 03:34 PM   #3 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
I use Oil-Dri at work (great for hydraulic oil), but that comes 50 bags to a pallet, 40lbs per bag. You can find similar stuff at Home Depot or Lowes. Any clay-based granular substance like kitty litter will do.
American by right
Ecomodder by choice
Hypermiler by necessity
Old 05-26-2009, 03:44 PM   #4 (permalink)
EcoModding Punk
LeanBurninating's Avatar
Honduh Power - '98 Civic HX
90 day: 44.37 mpg (US)
if its all soaked up and you are just trying to get rid of the stain... brake cleaner works great.
(flame shield ACTIVATE!)
Old 05-26-2009, 06:42 PM   #5 (permalink)
Sawdust works well if you get it down quick.
Ive heard cat litter is good too.
Old 05-26-2009, 09:53 PM   #6 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Cat litter to sop it up and diesel fuel to get rid of the stains. "Fight fire with fire"
Old 05-28-2009, 12:59 AM   #7 (permalink)
EcoModding EcoModder
wikityler's Avatar
Gerald - '91 Firefly 3dr
90 day: 40.08 mpg (US)
Does the diesel not leave a stain on asphalt like gasoline will?
Old 05-28-2009, 08:23 PM   #8 (permalink)
Hi-Tech Redneck
It will actually leave it so clean, you will want to do the entire driveway, but yeah, environmental hazard.
EPA! EPA! EEEEPAAA!............. (From The Simpsons Movie)
Old 05-28-2009, 09:33 PM   #9 (permalink)
well looks like I came to the party too late. we use the oil-dri at the shop and put it back in buckets as well. . .
Not really, We throw it down. . .leave it. . .scoop it up and throw it on the next one. There is always a car getting its oil changed so there is pretty much always somewhere that needs it.
Cat litter also works well as I've used that when I didn't want to run to the shed to get the oil-dri lol.
Old 06-01-2009, 01:19 PM   #10 (permalink)
PSmodder lurker
botsapper's Avatar
Best advice from Leanburninating, after soaking up most of the surface spills, use an environmentally better (relatively speaking) non-chlorinated brake cleaner. Cleans up most of the dark fluid stains on concrete floors/driveways . Hose down well and dries clean.
(Set shield up at 50%) (^_~)
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
