Old 01-05-2017, 10:40 AM   #11 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
A friend asked for a ride. I was in the middle of replacing a faucet, need to write progress reports for work, and have other things going on, but went to help. Then I ran into Walmart, which apparently now closes at midnight, and it was almost midnight.
I found teflon tape just in time and was almost home when I stopped for a train. I turned off my engine, but left my lights on so nobody knocked me into the train, except no one approached until almost ten minutes later, when I could see the end of the train. My phone was dying (and I cannot charge it in my Civic), but I was almost home!
Everything died when I tried to start the car. I had the smrtcar behind me back up and go around and I rolled back, but tried to bump-start when another car approached.
No good.
I got out and gestured for them to go around. They and another driver stopped to ask if I needed help and waited to see if I could bump-start.
Somehow the rest of the hill was steeper, but there are hardly any streetlights, and I could not turn on my lights. I was able to bump-start, but I kept worrying about backing into something I could not see!
I am very glad I have a manual transmission!
That was four blocks from home. In the morning I will get my trickle charger out of our shed, but that is in the alley. I do not enjoy long walks down dark alleys.
Like the old saying - $2 dollar helmet for a $2 dollar head! Obviously you place little value on the safety of yourself or your passenger.
Simon
Old 01-05-2017, 01:48 PM   #12 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Simon
A stationary car on a roadway is likely of minimal danger to anyone with a brain
Old 01-05-2017, 03:07 PM   #13 (permalink)
Ecomuggler
90 day: 40.43 mpg (US)
90 day: 33.55 mpg (US)
Originally Posted by JRMichler View Post
The battery might still be perfectly good. Put it on a charger for a couple of days. I use one of those 2 amp "computer controlled" chargers.
I put it on a charger in the morning and the green light was on before I left for work in the afternoon.
I hope you feel better now. By the way, no: Cheap or Expensive Bicycle Helmets
Summary: We submitted samples of six helmet models to a leading U.S. test lab: three in the $150+ range and three under $20. The impact test results were virtually identical. There were very few differences in performance among the helmets. Our conclusion: when you pay more for a helmet you may get an easier fit, more vents and snazzier graphics. But the basic impact protection of the cheap helmets we tested equaled the expensive ones. Just look for a helmet that fits you well.
Gasoline Fumes (01-05-2017)
Old 01-05-2017, 06:29 PM   #14 (permalink)
EcoModding Newb
90 day: 31.25 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 79.06 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 27.66 mpg (US)
As others have mentioned, your battery is likely on the way out if it isn't lasting 10 minutes.
I'd have turned the engine off too if waiting over a minute, but I also would turn the headlights off, leaving just the parking lights on. Blower motors are also consume a lot of electricity, so that should be turned off as well.
You should get a cigarette lighter charger for your phone. Even better, get one of those cheap batteries that can charge your phone several times and include a light. Amazon link
...and I'm curious, was your friend a girl? You need a friend as loyal and helpful as yourself.
Xist (01-05-2017)
Old 01-06-2017, 04:38 AM   #15 (permalink)
Ecomuggler
Redpoint,
Thank you very much for your kind words. I appreciate them.
I wish I had thought to turn off my headlights. I didn't need those!
I probably had the fan on low. Rolling down my windows and killing the fan might have made all of the difference that I needed, but the headlights would have been better!
I have car chargers, but they do not receive power. When I bought Chorizo there was another socket in the glove box, so I figured the previous owner had replaced it, but it still did not work. The fuse is good. I never tried troubleshooting further than that. It was good enough.
I have always thought about installing something like this: https://www.amazon.com/Arpenkin-Dash...o+usb+hardwire
I actually have a battery pack, but in the Accord, because I have been trying to establish its MPG, except I want a full tank at fifty-five, but I will remember halfway somewhere, and I do not slow down because I do not have time.
I want it in the Accord for road trips for a backup, but at least that car can charge my phone!
The battery pack needs to go into my Civic!
I may end up purchasing a non-Samsung phone because mine overheats just driving my black car in the Arizona summer without air conditioning. It would be much worse trying to charge it.
Friend was a bit of an overstatement. She is a girl, though, but that does not help me at all.
Thank you again for your feedback. I hope you have a great day!
Old 01-06-2017, 04:39 AM   #16 (permalink)
Duck duck duck
90 day: 54.26 mpg (US)
It - '09 Hyundai I10 Active Cool
90 day: 30.11 mpg (US)
Something like this would strike two in one blow:
4 In 1 Car Charge Display Temperature/Voltage/Amper 2979277 2017
2011 Honda Insight + HID, LEDs, UG, partial LGB, extra brake pad return springs, neutral wheel alignment, 44/42 PSI (air), PHEV light (inop), tightened wheel nut.
lifetime FE over 0.1 GigaMeter or 69 KiloMile
ksa8907 (01-07-2017)
Old 01-06-2017, 09:54 AM   #17 (permalink)
Since when is bump starting a car backwards in the dark without lights a stationary vehicle? And how many drivers on the road actually use their brain?
Simon
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
