Old 08-07-2009, 01:28 AM   #11 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 47.02 mpg (US)
It depends on how you setup the scangauge. You can program the scangauge to calculate fuel cut off on coasting. Or you can program scangauge to assume you idle on coasting in gear. How do you know what your fuel injector actually do so you can program your scangauge? Does anyone know a place to look this up or a way of determining. I'll do some searching to see if I find any answers.
Old 04-29-2011, 03:00 PM   #12 (permalink)
My Work Truck - '92 Accord LX
90 day: 43.39 mpg (US)
Latoya - '92 Pickup
90 day: 106.69 mpg (US)
The answer to your question is below.
I just finished some research on this exact topic. My findings are published here:
kc7ekk-solar.blogspot.com/2011/04/coast-in-neutral-or-in-gear.html
The answer is both.
With a cold engine, coasting in neutral uses 12% less fuel than coasting in gear. (at least for the default values in the computer of my wife's 2002 Chevy Venture). When the engine is warmed up, it flips the other way and coasting in gear saves on average 2.7% more fuel than coasting in neutral.
Old 04-29-2011, 03:03 PM   #13 (permalink)
Latoya - '92 Pickup
set the cut-off setting to 0
Before I messed with my scan gauge settings I was getting "9999" as the MPG during times of higher speed coasting. After setting "fuel cutoff" from 24 (default) to 0. My scan gauge was able to report back very high MPG readings without going into overflow mode (9999).
Old 04-29-2011, 07:37 PM   #14 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 49.12 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
What do you mean with "coasting in gear" ?
Pushing in the clutch and leaving the gear lever in the gear it was in ?
Lifetime fuel consumption :
Old 04-29-2011, 07:45 PM   #15 (permalink)
Latoya - '92 Pickup
coasting in gear == clutch engaged
"Coasting in gear", refers to letting off the gas but leaving the clutch in the gear it was in. Preferably a high gear so the RPM of the dead weight of the engine doesn't slow you down too much.
Old 04-29-2011, 10:28 PM   #16 (permalink)
Black Magic - '96 Civic HX
90 day: 46.51 mpg (US)
euromodder is probably going to tell you that DFCO (coasting in gear) is always worse, but I was theorizing about this on the way home from work today and I think it probably depends on how much braking you get from the engine. Some cars lose a lot more energy when in gear than others. I wonder if DFCO can out perform engine on coasting in certain long geared vehicles.
Old 04-30-2011, 06:56 AM   #17 (permalink)
Cartegena Uno Champ
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
Depends on the slope and coast. Coasting uphill (P&G) or on the flat then I slip out of gear and the SG2 shows 0.12 GPH and 300-500 MPG depending on speed.
On a slight downhill I can go into 5th or 6th and coast in gear - the gear chosen is low enough so that engine speed is above idle, so the car is 'turning' the engine and not the other way round. The fuel used drops to 0 GPH and 9999 MPH, and the loss of speed isn't that bad - enough to finish the slope.
On a steeper slope then in gear drops consumption to 0 GPH and MPG to 9999.
2011 Toyota Aygo Go!
Disclaimer - Postings from this author may be total rubbish. All figures in Imperial MPG unless specified. Use at own risk. Shake before opening. Store in cool, dry place.
Originally Posted by Gabriel Voisin about FWD
The system has the following merits: 1) It makes it easier to lower the centre of gravity and bring it forward. 2) It will free us from that unbelievable stupidity:a transmission shaft and tunnel between the engine in front of the driver and the driven wheels. 3) Front wheel drive will increase the interior space of the body, reduce the car's weight and diminish the cost price 4)It will annoy 320Touring by just being better .
How to post images in Ecomodder.
Old 04-30-2011, 07:26 AM   #18 (permalink)
euromodder's Avatar
Diesel
The MPG while doing so will be better than with the gearbox in neutral, as the fuel flow is cut off (DFCO).
But the downside is you won't get nearly as far.
Coasting in neutral and with the engine on is what lowered my fuel use considerably over DFCO.
I still underestimate just how far it'll roll
My car is a diesel, does DFCO right down to 1000 rpm, and the engine braking is considerable.
I've always made good use of the DFCO feature - well, before joining ecomodder that was - but it never consistently returned the kind of MPG I'm seeing now.
If you use MPG for recording, it'll bias towards DFCO, as you get towards infinite MPG (division by 0).
This can upset the readings you've taken.
Old 04-30-2011, 10:06 AM   #19 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
The real issue here is that coasting in gear (engine braking) is far more efficient than braking in neutral.
If you are truly coasting without the need to brake either at the moment or in the near future, coast in neutral. If you see a braking situation ahead, coast in gear.
Nissan Versa Aeromods
The Following User Says Thank You to skyl4rk For This Useful Post:
appuchan (06-14-2011)
Old 04-30-2011, 05:05 PM   #20 (permalink)
While in DFCO I have it setup to automatically turn on the EGR valve and try to equalize the pressure between the intake and exhaust manifolds. This increased the distance I can coast in gear with injectors OFF.
The Following User Says Thank You to tjts1 For This Useful Post:
justjohn (04-30-2011)
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 11:35 AM
EOC (keep in neutral or 5th gear?) Pillzilla Hypermiling / EcoDriver's Ed 18 08-25-2009 09:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 05:57 PM
Experiment: EV coastdown in gear vs. neutral (in the ForkenSwift) MetroMPG Fossil Fuel Free 6 03-17-2008 11:12 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
