Old 07-17-2009, 04:19 PM   #81 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
I'll cross-post quote myself here:
Originally Posted by PaleMelanesian View Post
Here's the problem with a bump-start at speed. The purple collar is spinning with the gold shaft at driving speed. The clutch is to the left, between the green shaft and the engine. When you engage the collar into either of the blue gears, it's spinning while the blue/red/green parts are not. That's what makes the grinding. The faster the vehicle is moving, the more likely that is. Synchronizers make the process smoother.
I have still not had any problems with this on my car, but you can see how it's possible.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 08-12-2009, 11:46 AM   #82 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 Golf wagon
90 day: 40.36 mpg (US)
Engine-off coasting with a manual transmission:
Shouldn't it be better to leave the transmission in gear and hold the clutch until the bump start?
Seems as if synchronizer wear would be more of a problem than clutch throwout bearing / pressure plate wear. Of course, by now my left leg is a bit shorter than the right one from all the clutch holding.
For synchronizer see PaleMelanesian's comments above. When the car is rolling with the engine off and you put it into gear, the tranny has to synchronize the engine's 0 RPM with the tranny's whatever RPM; not easy. If instead you simply disengage the clutch and turn the engine off without going into neutral, then when you want to restart the gears are already meshed and the synchronizer isn't needed.
For the clutch have a look at the illustration on HowStuffWorks "Fly Wheels, Clutch Plates and Friction"
When the engine is off, everything in the clutch is stationary except the clutch plate and output shaft to the tranny. That is, the throwout bearing and pressure plate are not grinding against each other (no wear), in contrast to when the engine is on.
Furthermore, if you leave the car in gear during EOC that's one less clutch press-and-release cycle (unless you pop it out of gear without the clutch), i.e. less usage of the throwout bearing.
Then of course there's the safety issue of being able to quickly restart the engine even when both hands are full (e.g. swerving).
You ever notice that birds pulse & glide, too?
Old 08-12-2009, 12:36 PM   #83 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
When you're neutral coasting, the only thing the synchronizer has to speed match is the input shaft and clutch disc... about 10 lbs, maybe slightly more.
When you're holding the clutch pedal in, the throwout bearing is fighting against the pressure of the spring action in the pressure plate, which could be 500# or more, depending on the application. You're also putting pressure on the thrust washer/bearing which holds the crankshaft in place laterally, causing wear to it as well.
Reference "crank walk" to see about thrust bearing issues.
Frankly, I'd rather not have to worry about crank walk.. I'd rather deal with a minute amount of wear in my well lubricated transmission, versus the potential of a throwout bearing exploding (again).
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 03-12-2011, 10:56 PM   #84 (permalink)
Liberty Lover
johnlvs2run's Avatar
honda - '99 civic ex
chevy - '89 celebrity
. - '00 .
Basjoos uses P&G a whole lot, and his clutch is approaching 500k miles.
Mine's just fine at 170k, p&g with bump-start for 99% of my driving.
That is awesome.
Is this correct?
The pulse consists of shifting up without using the clutch,
the glide is EOC in neutral with the key off and back on, and
the bump start is with clutch in 5th, then to the gear matching speed.
Is there a primer on how to practice especially the shifting without clutch?
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 11:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 02:28 PM
Coasting in Neutral... what if you can't come to a full stop after? Sean T. Hypermiling / EcoDriver's Ed 16 10-08-2008 01:11 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 04:49 PM
Neutral coasting vs In-Gear coasting Netherby Hypermiling / EcoDriver's Ed 1 06-13-2008 12:53 PM
