Old 07-17-2008, 03:39 PM   #21 (permalink)
Kawi - '04 Vulcan 800 Classic
90 day: 56.48 mpg (US)
The Monte - '99 Monte Carlo Z34
90 day: 26.52 mpg (US)
I've never heard of that. So all you have to do is let off the accelerator and the fuel cuts off and you are basically running with the engine "off" but still slowing down without using brakes? Is this on all new cars or just some?
Goal one= 30mpg on The Monte by changing the nut that connects the steering wheel to the seat.
Old 07-17-2008, 03:49 PM   #22 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
That's exactly right. Most new cars have the feature. It's there on my 1996 Honda, and all newer Hondas. One exception I know of is Hyundai - the Elantra as new as 2002 didn't have it.
Mine will fuel-cut in gear down to 1200 rpm, and then it starts feeding fuel again. You can feel a slight "surge" when that happens. You can downshift to put the rpm back above the mark and maintain fuel-cut. This works on automatics, too.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Neutral coasting vs In-Gear coasting Netherby Hypermiling / EcoDriver's Ed 1 06-13-2008 11:53 AM
Any Big Savings In Coasting In Neutral With Engine On? dsq Hypermiling / EcoDriver's Ed 25 06-12-2008 11:39 AM
Experiment: EV coastdown in gear vs. neutral (in the ForkenSwift) MetroMPG Fossil Fuel Free 6 03-17-2008 10:12 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
