Old 10-06-2008, 02:19 PM   #1 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 18.61 mpg (US)
Coasting in Neutral... what if you can't come to a full stop after?
So... today I was traveling down my all-time favorite road.
They just repaved it last weekend... omg. so nice.
And it is huge up and down hills. The first hill you can coast down for forever, and then a sharp incline to a stop light. I coast down, but can't shift to neutral because I know I can't make it to the top. (I've tried)
After that, there are some short hills followed by a HUGE valley. I can start coasting way back, reach the decline without losing any speed, then increase speed as I go down and retain 80% of that on the way back up. I can make it far enough to get to the stoplight about 1/4 mile after it starts to level back out.
Today, for the first time, I decided to try going down this hill in neutral because I noticed the light on the other side of the valley had just turned red... bad idea. I was about 10 car lengths away when the light turned green.
While this experience has turned me into a huge believer in Neutral Coasting (as soon as I shifted into N, I sped up by 5mpg, with no change in grade)... it also made me think... because I had heard that you should come to a complete stop before shifting into drive, I found myself abruptly coming to a full stop, so I could hurry up and shift into drive without the cars behind me catching up.
So I supposed my conundrum is... what is the best plan of action when you are coasting in neutral and find yourself in a position that doesn't favor you stopping and shifting back into drive?
My thoughts are put on the hazards and pull off onto the shoulder, shift, then merge back into traffic... well, what if there is a curb on each side of the road? Anybody have any thoughts or suggestions on any of this?
Old 10-06-2008, 02:23 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Where did you read that you have to stop to put it back into drive? Just rev match as well as you can and put it back in.
Old 10-06-2008, 02:38 PM   #3 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
really? What do you mean by rev match? match them to what?
Old 10-06-2008, 02:39 PM   #4 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
I thought I read it on here... wherever it was it was a long time ago.
Old 10-06-2008, 03:24 PM   #5 (permalink)
CM400E - '81 CM400E
Rev match just means to rev the engine up to match the rpm it will be at once it is in gear. This is always a general guess with an automatic. Really, as long as you don't feel the car jerk as it goes back into gear, you are fine.
Old 10-06-2008, 03:39 PM   #6 (permalink)
the shoe - '97 Civic CX
90 day: 28.2 mpg (US)
I've been neutral coasting the last couple weeks in my automatic. I haven't noticed much car jerking going back into drive. There were only a couple small instances of this. I've found it very smooth.
HHINLA
Old 10-06-2008, 04:04 PM   #7 (permalink)
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Most cars handle the shift into Drive with no problems. The only one that gave me issues was an '08 Kia Rio. (It had other problems anyway; if you shifted from Reverse into Drive if you were rolling backwards at all, it would lock up the tires. I've never had an auto do that before.)
I'll echo what others have said. If it finds the right gear and goes into Drive relatively smoothly, you're fine.
Old 10-06-2008, 04:22 PM   #8 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
I always give the car a couple seconds to "rev match" after putting it back into drive...especially when neutral coasting at higher speeds (highway or steep downhills). When going from neutral to drive you can see the rpm's go back up to around 1500 from approx. 500...then use the accelerator to ease back up to speed.
Old 10-06-2008, 05:09 PM   #9 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
In my situations, I simply drop it back into neutral, the transmission does its own version of rev matching, it will spike the rpms to lets say 2200 befor lowering back down to 1700. SO basically I shift and wait a couple of seconds before engaging the accelerator again.
4 months in to P&G @ highway speeds, no ill effect or wierd noises.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 10-06-2008, 05:13 PM   #10 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
My wife's car is an automatic and anytime I nuetral coast in it I just shift back into drive and it always shifts back into gear smoothly, then I just accelerate as normal.
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 11:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 02:28 PM
EV Mode Coasting - go to Neutral? cephraim General Efficiency Discussion 0 08-29-2008 11:21 AM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 04:49 PM
Neutral coasting vs In-Gear coasting Netherby Hypermiling / EcoDriver's Ed 1 06-13-2008 12:53 PM
