Old 03-30-2010, 07:17 PM   #1 (permalink)
coil for motor voltage
less heat and waste is generated by higher voltages against amps. In a vehicle powered by car batteries would it be a good idea to run the output of the batteries through a coil to raise the voltage? Would the electric motor generate less heat and possibly have more torque?
Old 03-30-2010, 08:32 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...an *added* coil would introduce additional DC-resistance which would consume even MORE power.
...you cannot "step-up" DC-voltage, as from a car battery, using a coil.
...you need either AC-voltage and a transformer, or a "switching" coil-capacitor (LC) network and circuitry (like switching power supplies).
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 03-30-2010, 09:54 PM   #3 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I don't understand the question.
If you want higher voltage get higher voltage batteries and bump up the whole systems voltage.
Old 05-03-2010, 06:44 AM   #4 (permalink)
Originally Posted by kidashley25 View Post
does it cause higher voltage?
in laymans terms it should create higher voltage at a much lower current but as explained above there are reasons it shouldn't/wouldn't work......
electric motors running on higher voltage is MUCH better than a lower voltage with higher amps...............the brief idea here being use only a few batteries (say 4 which is what you will get into most cars) then convert to a higher voltage to run your motor.
Old 05-03-2010, 09:24 PM   #5 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Villager gs
90 day: 19.8 mpg (US)
Max - '98 Maxima SE
90 day: 26.89 mpg (US)
It may be cheaper and more efficient to get more batteries, which wouldn't need to be large ones, mind you. And i do believe you could step up the voltage, but you would lose efficiency through the transformer. 12 volt batteries come in all sorts of shapes and sizes--motorcyle batteries are quite small.
With higher voltage, though, you would be hard pressed to find an inexpensive motor controller, unless you went with an AC motor, if I'm not mistaken. Most of the OEM plug ins use an AC motor and run around 300v battery voltage.
Gotta love wife, kids, and car!
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-03-2010, 09:51 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
just to muddy the waters a bit, most of the ac controllers I've seen actually have a coil, for "power factor correction", but the result is that it can bump the 300 volt battery up to 500 volts (with a corresponding drop in current and some losses).
I haven't studied many DC controllers but I haven't seen such a device employed there solely as a boost converter. Though there is certainly appeal in being able to make higher voltage from fewer large and cheaper batteries, I don't know what the tradeoffs are exactly. Bet someone here does though
Old 05-04-2010, 10:29 AM   #7 (permalink)
...beats walking...
...inductor "stores" energy in an electromagnetic field
...capacitor "stores" energy in an electrostatic field.
...resistor does NOT "store" energy, it can only "dissipate" it.
...only AC-voltage can be "stepped-UP/DOWN"
...but, DC-voltage can be "converted" into AC-voltage (but always at a loss).
Old 05-08-2010, 12:50 PM   #8 (permalink)
Basjoos Wannabe
Max - '98 Maxima SE
not to try to start an argument, but if dc can't be stepped up/down, what is a dc/dc convertor? or a cell phone car charger?
26.2 mpg Toyota Previa. Go Golden Egg! orange4boy Success Stories 43 02-06-2011 04:48 AM
Geo Metro Suspension Swap (to handle extra battery weight) bennelson Off-Topic Tech 29 04-06-2009 11:00 PM
Help ! Tijeff Off-Topic Tech 3 02-28-2009 08:52 AM
Coil spring clamps tasdrouille Off-Topic Tech 2 04-24-2008 10:11 AM
